It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it. YOUR
SAFETY IS PARRAMOUNT This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
