DigiLife DDV-M1 Flash Media Camcorder Logo
Question about DigiLife DDV-M1 Flash Media Camcorder
I had my digilife ddv-1100 for approximately three years and It no longer charges. If I pulg the usb in the light comes on but as soon as I disconnect it it goes right back off. What could be the problem? If My battery is the problem where could I acquire a new battery?
Posted by dejuan629 on
Anonymous
    Genius:
  • 1,177 Answers
Almost certainly the battery. They don't last forever.
MY DigiLife DDV 7000 uses an NP-60 battery. I found some of these on Amazon by searching for "np-60", and paid about $1.50 each. You can also sometimes find batteries by searching on the Camera's model number.
My camera does not charge the battery from the USB lead. I have to use a separate charger.
Posted on Jan 05, 2011
Testimonial: "Thank you I appreciate the help with my camera problem, I was going through it trying to find a battery."
How to use digilife DDV 7000 cmcorder as a webcam? can't use the flash of digilife DDV 7000 cmcorder
You have to install a driver to use this camera as a webcam. There is a Windows one posted at:
this site
It is actually for a different model, but works. Once you have installed it, your camera will show up as a source when you use a program that captures webcam pics or video. You will need to connect the camera to your computer with a suitable USB lead.
To turn the flash on and off in still picture mode, you press the right pointing arrow on the round selector switch array. There are two settings, off and auto, so you cannot force it to flash- it will only do it when the camera decides the light is low. The flash does not work when filming video.
1helpful
Can I get the instruction for using my Digilife DDV-330 camcorder, is there a way to down load
Hi and Welcome to fixyah,
Here check this link http://vr-zone.com/print/-digilife-all-in-one-ddv-c330-camcorder/3583.html
Problem ddv-v1
la verdad no se entiende tu problema se mas especifico charly
2helpful
Is not DDV-C330, is Digilife DDV-6120A
Find the DDV-C330 manual for download here:
http://chinamanuals.com
It is the same cam like the 6120A
Digilife DDV-7300 Camcorder - Battery will not hold charge
Not sure of which model exactly your using, but you may check out the web address below.
It appears to be a Chines manfactured Brand, unfortunately alot of these units appear to suffer from a substandard charging system that leads towards a problem with the battery.
The good news is that many mobile phone batteries are often suitable replacements for these to swap out with. I'm picking its probably around a 4.8v or similar flat type battery and is charged either via computer USB connection or through independant charger. A local camera shop won't be a good bet, the shipping to china may out weigh the cost of replacement. I would suggest hunting for a custom battery manufacturer that can supply a replacement battery and hopefully a charger to suit! :o)
As for the on off switch, also a common flaw in the designs, any local video camera repair shop should be able to assist with that part of it. Hope this helps.
http://www.lightinthebox.com/producttags/Digilife-Camcorder-Ddv-C330/
5helpful
My Digilife DDV-1100
the camera's battery won't charge with the usb cable connected to the computer, only with the 110/240 v charger. Hope I can help
1helpful
2answers
DIGILIFE DDV-7300 CAMCORDER
i ve digi life ddv-7300 model purchased in singapore one year back now its working when shown to service centre they said menu script prob and spare are rarely available. so wat can i do now
Top DigiLife Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
ray gallant
Are you a DigiLife Video Camera Expert? Answer questions, earn points and help others
