Cameras Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have just bought the Fuji JX530. When I take a picture I get a split second clicking sound coming from the lens before the flash goes and the picture is taken. The picture is fine and the mechanism moves smoothly when turned on/off and zoomed in/out. Is this just the normal operating sound of the lens or something else ??
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jan 05, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200436
Points
38521
When you press the button, the camera performs many functions in a split second such as set the focus, set the aperture and shutter speed, calculate the flash power, etc. It will make sounds and if the pictures are fine, then all is well.
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
When I try to turn on my FinePix A600 is beeps, the lens comes out, the light on the back flashes yellow, then it flashes red, the lens goes back in and the camera turns off. I bought a second FinePix...
I'm curious....the camera came out in 2006....how did you buy a second one?...and more importantly, why? If something doesn't work, the first thing people do isn't to go out and buy another one. Anyway, from your description, the problem seems to lie with the cards, not the camera. All memory cards must be formatted (sometimes called "initialized") in the camera before use and regularly after downloading the pics to the computer. This erases the card and brings it back to original condition so download any pics you want to save using a separate cardreader if necessary and then, format/initialize them in the camera.Also, how old are these cards?....they don't last forever.
How do i get the date to display on pictures I take of my Fuji Finepix JX530
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
3helpful
Has the Fujifilm JX530 been launch yet, and are there any problems with it
Hi I bought this camera 2 days ago and could not download the disc for the manual . I rang fuji up to explain and they sent me a manual free of charge which i received this morning . Hope this helps !
2answers
Hello guys fuji film s1 pro problem
From the Fuji S1 Manual:
F-- (Flashing) or (lit in M Mode)
Cause:
The lens mounted is not a Nikkor lens with built-in CPU or no lens is mounted on the camera.
Solution:
Use a Nikkor lens with built-in CPU (excluding IX Nikkor lenes). (Note that pictures can still be taken in M mode.)
Fuji Finepix split screen
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
