Question about D-Link DIR-300 Wireless Router
I don't know how to lock my wireless network so nobody eale s esu it .
Posted by monabuddy on
Computer hardware and networking support
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jan 05, 2011
Cannot connect to network
Let's get you connected!
Please Note:A broadband Internet connection and wireless router are required. Follow the steps below to get connected.
For a step-by-step video tutorial, click here.
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
  2. Scroll over to the third page, and select "Internet."
  3. Now choose "Connection Settings."
  4. Click on "None" for "Connection 1."
      connection_1.png (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  5. Click on "Search for an Access Point."
  6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network. (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi. Click the image below that matches the lock icon you see on the screen of your Nintendo DSi.
Aug 14, 2011 | Nintendo Dsi Pink Console
Need to unlok my treo 750 nobody seams to be albe to find the unloking code
You can get the Unlock code from service provider and Unlock it...
Aug 07, 2011 | Cell Phones
How do you connect internet
1. Turn it on and access system settings. [[wrench icon]] 2. Scroll to page 3 and select "Internet" 3. Choose connection settings. 4. Click on "None" for "Connection 1." If you don't see "none" option for Connection 1? Make sure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings."
5. Click "Search for an Access Point." 6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network.
7. What you'll do next is choose the open lock, gold closed lock, or silver lock...
Open lock: No security.
8. Select ok, save settings, then yes. Once you see connection successful... the support code is unimportant.
Jul 09, 2011 | Nintendo DSi Blue Console
How do i make sure nobody else is using my internet without my permission?
You need to set up a network password to keep others from piggy-backing onto your internet connection and to secure others from accessing your data. I can walk you through the process if you give me your router''s manufacturer and model.
Jun 26, 2011 | Computers & Internet
How do i put a lock on my wireless router
Are you trying to lock it so no one can connect to your network, or lock it so that no one can access the setup? If you're trying to make it so no one can connect to your network, go to your router setup page(192.168.1.1). If you haven't changed the password for the setup page, it should be Username: admin Password: password. Look for Wireless Security, and add a WEP key. Once the router resets, your computer will ask for a key to connect to the network. Just type in what you made the key and you'll be connected.
If you want to lock it so nobody can change the settings, you'll need to do that from the settings page just like last time, except this time look for Administration. Usually it's one of the last tabs. In there you'll see the administrator password. Just change this and you'll have it locked.
Jun 15, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Idid the steps and say its connected but nothing to be trust I don,t want anybody get my internet I don,t know is th router get the password
Feb 07, 2011 | Linksys Wireless-G Broadband Router
How do i put security code so no one else can pick up wireless
Connect to the web-server "inside" the router, and run the Wireless Network Setup Wizard", and choose a SSID and choose a password.
Tell *NOBODY* the password -- they still can see that your network exists, but, without the password, they cannot connect.
Compare it to telling people your address, but leaving the outside doors locked; they can see your home, but they cannot enter.
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
BMW recharge battery with a car
not recomended, because your car and the other one has computers, take your cables off your battery both of them, negative and positive, this is very important so you will not damage your ESU. or damage the othe cars ESU. connect jumpercables from your other car to your battery, turn on the other car, let car idle for about a half hour, to fully charge your battery provided your battery is in good shape. remove cables from your car and the other car, attach your cables back to your battery than start, DON NOT start your car with other car still attached to you battery, you are risking blowing the ESU on your other car. and damaging your ESU. [email protected]
Feb 22, 2009 | 1999 BMW 323 Series
Security lock
If it doesn't come up with user and password screen do a reset to factory defaults. Here is a link for your manual. There's a version number after the 614 I believe it's on the bottom. Just choose the correct version for manual and ifo and firmware. The NAT's will protect your network but read the manual. Not very hard. Please rate if helpful. Thanks. http://kbserver.netgear.com/products/wgr614.asp
Mar 19, 2008 | NetGear WGR614 Wireless Router
D-Link DIR-300 Wireless Router Logo
53 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
