Question about NetGear WG602 802.11g/b Wireless Access Point
How can i configure netgear wc602 with thoson tg585
Posted by m0mayaz on
Can't access 192.168.0.227
This configuration IP address is wrong for the Netgear.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 25, 2012 | NetGear WG602 802.11g/b Wireless Access...
I have changed networks and i dont know how to re configure my WGT624 netgear router
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = password You can now change the admin password and configure thewireless settings.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 04, 2011 | NetGear WGT624 Wireless Router
Hi, I can't open the main modem configuration page. the modem is (thomson tg585 v8. and the page adress is 192.168.1.254 it opens for a minut or so after turning it off then on, then it shows explorer...
Please try one of the following option:
Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
If your computer runs Windows Vista or Windows XP, you can also access the Thomson Gateway Web Interface using the Internet Gateway Device icon.
If you computer runs Windows Vista:
1 On the Windows Start menu, click Network.
2 The Network window appears:
3 Right-click your Thomson Gateway (displayed as THOMSON TGXXX) and click View device web page.
4 The Thomson Gateway Web Interface appears.
If you computer runs Windows XP:
1 Go to My Network Places.
2 The My Network Places window appears:
3 Double-click your Thomson Gateway (displayed as THOMSON TGXXX).
Be sure you don't have any popup blocker or firewall interfering.
For more reference here below the manual (Version 7 that is basically the same of V8)
http://www.cytauk.com/cytauk/userfiles/TG585-v7_SetupUserGuide_en_pdf.pdf
regards
Mar 22, 2011 | Computers & Internet
I have a PS3 and I want to change nat type from strict to open when I play Black Ops. My router is a Thomson TG585 v8. How can I do that? Thank You in advance
Hi, I'm not familiar with Thomson routers, but you can watch this video, which details the process for a netgear router. The process will most likely be similar for your router.
Feb 27, 2011 | Video Game Consoles & Games
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Cannot reset to factory defaults Thomson TG585
You need press the reset button at least 15 seconds
Dec 25, 2008 | Computers & Internet
Wireless computer not working
1. make sure that the wireless card is properly installed in your computer. (if it is a laptop, make sure that the wireless switch is on).
2. make sure that the distance of the wireless router and wireless pc is not very far
3. if you know the wireless configuration of your router proceed with number 4, if not see my note below.
4. right click the wireless icon on the pc, choose 'view available wireless network' or connect to a network.
5. check if your SSID is showing. If it is showing and it says secured, click on it and enter your encryption (either WPA or WEP or WPA2).
6. if SSID is not showing, go to the router configuration page and change your channel. play around with your channel until your non working pc sees the SSID.
note(checking router configuration): on the wired pc, open internet explorer browser, type http://192.168.0.1 (default username is admin & password is password or 1234) Note: if you changed your ip address or password on the router, use that.
Aug 28, 2008 | NetGear WGR614 Wireless Router
NetGear WG602 802.11g/b Wireless Access Point Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
efs_perpends
efs_perpends
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
