Question about Aqua GPS
I have an aqua-vu scout xl-50 under water camera. when i turn it on there is only about a 1 1/2" picture across the screen. the batery charger no longer lights up but the camera still works some what. if i disconnect the cable where the joint conector is i get a full screen picture on the screen' but of course it is just a plain whiye screen. wwhat is my problem ? can you help me?
Posted by nyvee01 on
1 Related Answer
travelbobgau
  • 6 Answers
SOURCE: i have an aqua vu scout and it has good battery
mike if you are still having this problem, i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Posted on Jan 25, 2011
Screen and camera lite up, but why no picture and no focus?
Check your camera cable & 'FISH' camera for kinks,punctures, or tears. Reconnect the cable into the monitor. Have a nice day.
Jan 04, 2016 | Aqua Vu Scout SRT Fishfinders
It powers on but the screen does not turn on.never has worked since we bought it. called the teck service said that not possible so my buddy gave up on it.I put a new battery in it green lite comes on but...
Check the battery voltage. It should read around 12 volts. I have the same unit that did the same thing. The battery voltage was down to 6.5 volts. That was enough to power the LED but not enough to run the unit. Once I used a known good battery everything worked fine. Good luck!
Jan 21, 2011 | Aqua Vu Scout SRT Fishfinders
We took a few pictures the night before we went to a museum. That night we put the battery for the camera in a charger that plugs into an outlet. This batery was taken out of the camera. The next...
Cushioned or not, your camera likely landed on the end of its lens, dislodging it from the track it rides on to zoom, or jamming it on the track so that it cannot move, and the camera powers itself off to prevent further damage when it senses the lens problem. You can try a home remedy by powering the camera off, and then holding the zoom button while you power up. Sometimes that will pop the lens back on the track and restore function. You can also try GENTLY pulling on the lens while you power the camera on (or GENTLY pushing if the lens is extended). Some owners have reported success by GENTLY tapping the lens end on a firm surface, but that can also cause more damage. If all else fails, you'll need to get a repair quote (NOT an estimate) from Kodak.com or your local Kodak repair point to decide whether or not the camera is worth the cost of repair (some repairs can exceed the cost of a new camera).
Jan 18, 2011 | Kodak EasyShare P850 Digital Camera
I have an aqua vu scout and it has good battery and connection but no picture
Dec 23, 2009 | Aqua GPS
My trail sentry will not let me reset the code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
Oct 04, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Decode to reprogram new pass word
Try this:
Sep 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
May 13, 2009 | LG Vu CU920 Cellular Phone
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Aqua vu underwater camera
Aug 09, 2008 | Aqua -Vu Perch Underwater Camera with...
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
GPS Logo
200 people viewed this question
Top Aqua GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Aqua GPS Expert? Answer questions, earn points and help others
