Question about Dacor 36 in. Preference SGM364 Gas Cooktop
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
SOURCE: after cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Posted on Jun 15, 2010
SOURCE: One of the burners on my Dacor 4 burner gas
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
SOURCE: I have a 5 burner
The switch behind the knob is bad..
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
SOURCE: 10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Dec 14, 2010 | GE Profile JGP636 Gas Cooktop
Jun 11, 2010 | GE Profile JGP636 Gas Cooktop
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
Apr 02, 2009 | GE Cooktops
Mar 14, 2008 | Cooktops
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
Nov 13, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
372 people viewed this question
