What country have a code of 88? - Computers & Internet
Posted by soniemuji on
amit KUMAR
  • 186 Answers
+88 is not a country code. There are country codes beginning '88' but they are 3 digits long.
like :-
(1) +880Bangladesh, (2) +881Global Mobile Satellite System, (3) +882International Networks, (4) +883International Networks, (5) +884Unassigned+885Unassigned, (6) +886Taiwan, (7) +887Unassigned, (8) +888Telecommunications for Disaster....
etc
Posted on Jan 05, 2011
vishag k v
  • 409 Answers
A country code of 88 belongs to Bangladesh, a country in southern Asia.
Thanks for rating
Maximum allowed FM TX wattage in South Africa?
I would strongly suggest that you investigate the rules about transmitting in that country. 88-108 in the US is reserved for commercial broadcasting (FM). Are you a US citizen? If so, I would recommend that you get your Amateur Radio license in the US which is usable in most other countries. Then you are legal. (But only in the frequencies for that country.)
Jan 23, 2018 | Walkie Talkies Radio Communications
Water heater code 88:88. What does it mean. We have no hot water
The 88:88 code indicates the heater is not operating.
Jan 07, 2018 | Water Water Heaters
1988 rodeo high beam relay location
no country stated, no that DOES make this hard.
lighting does very by country, (DOT laws ......)
no symptoms posted. sigh
very old car.
why does wiki show 89 as first year.?
why is 88 missing in alldata.com
my guess, is 88 is build date? and not official mfg year date.
sold under 10 different names
my on line page shows, 1991 rodeo (usa)
head light relay , with 4 pins and the red-blue wire.
ok location.
the fsm im views shows a man with hood open
and removing the fuse box clear cover. and on said cover is the words. head lights, over the Relay spot.
lost the cover? or even look under the hood.?
there is a cab fuse box too with same markings.
the car came new, with the operators guide (sure lost) and has all that there. all fuses and relays.
quote.
Sales of the three-door began in the United States during the second quarter of 1989 under the Isuzu Amigo name
http://en.wikipedia.org/wiki/Isuzu_Wizard
see why not saying country , makes this car so hard.... link above.
Jul 31, 2014 | Isuzu Rodeo Cars & Trucks
Code 88
In reviewing the GM OBD I code list, there is no code 88
FAQ How to read older GM codes for free
Mar 23, 2014 | 1995 Cadillac DeVille
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
Jul 22, 2012 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
What is +88?
it is the country code...Like India has its country code that is +91 like this it is also a country code.......
Oct 18, 2010 | Cell Phones
I am looking for the cylinder head torque specification for the 3.3litre chrysler town and country 2003
Tighten the cylinder head bolts 1 - 8 in the sequence shown in Cylinder Head Bolts Location and Tightening Sequence Using the 4 step torque turn method, tighten according to the following values:
Step 1: Bolts 1 - 8 to 61 N·m (45 ft. lbs.)
Step 2: Bolts 1 - 8 to 88 N·m (65 ft. lbs.)
Step 3: Bolts 1 - 8 (again) to 88 N·m (65 ft. lbs.)
Step 4: Bolts 1 - 8 turn an additional 1/4 Turn. (Do not use a torque wrench for this step.)
NOTE: Bolt torque after 1/4 turn should be over 122 N·m (90 ft. lbs.) If not, replace the bolt.
Tighten head bolt number 9 Cylinder Head Bolts Location and Tightening Sequence to 33 N·m (25 ft. lbs.) after head bolts 1 - 8 have been tighten to specifications.
Jan 24, 2010 | 2003 Chrysler Town & Country
My unit turns on, flashes 88 and then goes dead.
Question
What does code "88" mean? What should I do if code "88" appears?
Answer
What does code "88" mean? What should I do if code “88” appears?Code “88” indicates that the saltwater system is standing by, please simply set the operation hours according to the manual and the system will start working.
Jun 21, 2009 | Intex Automatic Salt Water System for ...
Nokia 3120 Caller ID Display
Save your numbers along with country code. Like +8801719002255. Here +88 is country code and rest is mobile number. Your porblem will be solved.
Apr 26, 2008 | Nokia 3120 Cellular Phone
Computers & Internet Logo
2,018 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
