Question about Microsoft Office Computers & Internet
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Posted by kanchana_amm on
Anonymous
    New Friend:
  • 11 Answers
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Posted on Jan 05, 2011
HELLO SIR, MY MS OFFICE IS NOT GIUNEN WHT I DO THANKS
search for a serial key or crack of your MS Office version or download it from any torrent site & re-install it, hope your prob will get solved....
Sep 24, 2010 | Microsoft Office Professional 2007 Full...
Front page in MS office 2007
There are different "packaging" options for MS Office 2007.
When you installed MS Office, did you choose "Advanced" install,
and did you enable/disable the installation of Front Page?
Click Start.
Click All Programs.
Click Microsoft Office.
Do you see "word" and "excel" and "powerpoint" and "front page" ?
Just some of these programs?
Sep 18, 2009 | Microsoft Office Professional 2007 Full...
Miss ms office 2007 product key
Hey Hi,
HERE ARE THE ACTIVATION KEYS
Microsoft Office 2007 Professional
XC84W-M642D-2QDWY-YTKMM-RWJQW OR TCCMP-PXGHB-3TR88-6WDCX-2HDBD
OR H36BT-QFYMQ-FCFC3-KYQ69-G67PT
T3PVR-XX42X-T49DW-WGBG6-9FT73 OR C3T4B-8MD24-46K4H-6XPPX-VD6YD
OR DM6GQ-HM9CG-HCVY9-T3C74-GVHVW
MS Office(Home and Student) 2007: GHJGD-TWT9Y-G7H42-FWDJK-3G6KW
MS Office(Home and Student) 2007: KRBWK-TVGBX-3KQG4-H7WXG-KQGKM
Microsoft Office Home & Student 2007: JWR9T-HFR92-74RQ7-3FRMB-CY676
Norton Antivirus 2008:VGH96-FY8HM-443GH-F4Y36-PYH98
Microsoft Office Home & Student 2007: TW6JJ-D28JW-B7KRM-44W66-MGVGY
Microsoft Office 2007 Home and Student: B4MKP-KP9YP-7TBQ4-7T4XF-MTGWY
Microsoft Office 2007 Home and Student: DDY79-433JV-2RXGX-MQFQP-PFDH8
Microsoft Office Home and Student 2007: DDY79-433JV-2RXGX-MQFQP-PFDH8
Microsoft Office Home and Student 2007: B4MKP-KP9YP-7TBQ4-7T4XF-MTGWY
Microsoft Office Home and Student 2007: KGFVY-7733B-8WCK9-KTG64-BC7D8
Microsoft Office Small Business 2007: S/N: CKMPB-6B4QT-MG4C6-2VH4C-RDD43 Or HTPWX-FR6J8-2WBCQ-T63JR-3M8PD
A Few Activation Keys for Office 2007 Home and Student.
More on the Way for different MS Products
Visit us at thedeadlyghost dot com.
before visit this site try the following key.
1-HBC66-D6YR7-CRP7H-T8VP4-99PMW
2-QXMDH-CRYFM-QFR87-HB783-T7RFQ
3-P37JV-FYJ32-YHH3T-KX7GX-7BJY3
4-HRMGX-K8WKJ-7FBGW-FTBCY-DWCM3
5-RCFMT-WFT7M-R779R-BJQMB-M2KWD
6-T9HJX-4C3BM-MG2R6-WC933-RCBRT
7-BTT7P-9HBFP-6QHM7-RFHDV-X8XWG
8-HWMMV-7H4DT-J2PJ6-YB8X4-VQCM6
9-JM2QC-KMVTP-VR8GV-HJRKQ-YWXWG
10-BHD34-K6BT7-T6PXP-BXKT4-X3G8D
11-DDH8T-C2JGD-G6MWW-6CYBV-BDTB6
You have one more option which is OPEN OFFICE which is a free competitor to Microsoft office that does many of the same things.
CLICK HERE TO DOWNLOAD OPEN OFFICE
RATE THIS SOLUTION ACCORDINGLY
If In Case You Need Any Further Help Reply Back To This Post
Best Wishes
Vick...(",)
Jun 13, 2009 | Microsoft Office Professional 2007 Full...
I need a product key code for ms office 2008 for mac?
HERE ARE THE ACTIVATION KEYS Microsoft Office 2007 Professional XC84W-M642D-2QDWY-YTKMM-RWJQW OR TCCMP-PXGHB-3TR88-6WDCX-2HDBD OR H36BT-QFYMQ-FCFC3-KYQ69-G67PT Microsoft Office Professional 2007 T3PVR-XX42X-T49DW-WGBG6-9FT73 OR C3T4B-8MD24-46K4H-6XPPX-VD6YD OR DM6GQ-HM9CG-HCVY9-T3C74-GVHVW MS Office(Home and Student) 2007: GHJGD-TWT9Y-G7H42-FWDJK-3G6KW MS Office(Home and Student) 2007: KRBWK-TVGBX-3KQG4-H7WXG-KQGKM Microsoft Office Home & Student 2007: JWR9T-HFR92-74RQ7-3FRMB-CY676 Microsoft Office Home & Student 2007: TW6JJ-D28JW-B7KRM-44W66-MGVGY Microsoft Office 2007 Home and Student: B4MKP-KP9YP-7TBQ4-7T4XF-MTGWY Microsoft Office 2007 Home and Student: DDY79-433JV-2RXGX-MQFQP-PFDH8 Microsoft Office 2007 Home and Student: DDY79-433JV-2RXGX-MQFQP-PFDH8 Microsoft Office Home and Student 2007: DDY79-433JV-2RXGX-MQFQP-PFDH8 Microsoft Office Home and Student 2007: B4MKP-KP9YP-7TBQ4-7T4XF-MTGWY Microsoft Office Home and Student 2007: KGFVY-7733B-8WCK9-KTG64-BC7D8 Microsoft Office Small Business 2007: S/N: CKMPB-6B4QT-MG4C6-2VH4C-RDD43 Or HTPWX-FR6J8-2WBCQ-T63JR-3M8PD A Few Activation Keys for Office 2007 Home and Student. More on the Way for different MS Products Visit us at thedeadlyghost dot com. before visit this site try the following key. 1-HBC66-D6YR7-CRP7H-T8VP4-99PMW 2-QXMDH-CRYFM-QFR87-HB783-T7RFQ 3-P37JV-FYJ32-YHH3T-KX7GX-7BJY3 4-HRMGX-K8WKJ-7FBGW-FTBCY-DWCM3 5-RCFMT-WFT7M-R779R-BJQMB-M2KWD 6-T9HJX-4C3BM-MG2R6-WC933-RCBRT 7-BTT7P-9HBFP-6QHM7-RFHDV-X8XWG 8-HWMMV-7H4DT-J2PJ6-YB8X4-VQCM6 9-JM2QC-KMVTP-VR8GV-HJRKQ-YWXWG 10-BHD34-K6BT7-T6PXP-BXKT4-X3G8D 11-DDH8T-C2JGD-G6MWW-6CYBV-BDTB6 RATE THIS SOLUTION ACCORDINGLY If In Case You Need Any Further Help Reply Back To This Post Best Wishes Dude Regards Vicky...(",)
Jun 10, 2009 | Microsoft Office Professional 2007 Full...
Ms office 2007 key
All questions regarding product keys for Microsoft Office products can be taken care of at:
www.microsoft.com/office
Aug 09, 2008 | Microsoft Office Professional 2007 Full...
Ms offcie 2007 key
this product key works..
swear i use it in my laptop.. and it functions well..
rate me after if it does..tnx!!
Jun 22, 2008 | Microsoft Office Professional 2007 Full...
Open Questions:
KYOCERA PRINTER Customer care Phone nUmber+1800 828 0294 Get easy steps to forgot or change KYOCERA PRINTER customer care rKYOCERA PRINTER via phone number 1800 828 0294 just follow some steps to recover KYOCERA PRINTER customer care while you want. In varoius conditions many people lost their account customer care and much more secure information or information may be hacked by anyone so in that case people want to configure KYOCERA PRINTER with KYOCERA PRINTER or other microsoft account services. Their are many certified officer to suggest people that how to change or rKYOCERA PRINTER KYOCERA PRINTER voicemail customer care using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to rKYOCERA PRINTER KYOCERA PRINTER customer care to rKYOCERA PRINTER or change it quickly, if you have any of them so contact to get well KYOCERA PRINTER care form us. KYOCERA PRINTER customer care rKYOCERA PRINTER not working XEROX PRINTERcustomer care rKYOCERA PRINTER phone number KYOCERA PRINTER customer care rKYOCERA PRINTER contact number KYOCERA PRINTER customer care rKYOCERA PRINTER help KYOCERA PRINTER customer care rKYOCERA PRINTER care KYOCERA PRINTER customer care rKYOCERA PRINTER wont work KYOCERA PRINTER customer care rKYOCERA PRINTER wont work KYOCERA PRINTER customer care rKYOCERA PRINTER link KYOCERA PRINTER customer care rKYOCERA PRINTER issues KYOCERA PRINTER customer care rKYOCERA PRINTER usa KYOCERA PRINTER customer care rKYOCERA PRINTER customer care service. XEROX PRINTERemail account customer care rKYOCERA PRINTER ' free KYOCERA PRINTER email customer care care ' cannot rKYOCERA PRINTER KYOCERA PRINTER email customer care ' KYOCERA PRINTER email customer care care ' KYOCERA PRINTER email customer care care download ' KYOCERA PRINTER email customer care care software ' free KYOCERA PRINTER email customer care care . KYOCERA PRINTER email customer care change, KYOCERA PRINTER email hacked customer care changed, KYOCERA PRINTER email hacked can't change customer care, change KYOCERA PRINTER email customer care on iphone, change KYOCERA PRINTER email customer care on ipad, change KYOCERA PRINTER email customer care on android, KYOCERA PRINTER email account hacked can't change customer care, how to change KYOCERA PRINTER email customer care on droid, KYOCERA PRINTER email customer care problems, KYOCERA PRINTER email customer care not working, KYOCERA PRINTER email account customer care rKYOCERA PRINTER.
Apr 04, 2019 | Microsoft Computers & Internet
Computers & Internet Logo
217 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
