Question about Electrolux EW1200i Front Load Washer / Dryer
My 1200I washes ok but does not get to spin speed, I suspect its the motor brushes, is this correct?
  • 2,509 Answers
It seems unlikely as if the motor brushes were worn I would expect problems making the motor turn at all. It would seem that a number of owners have had the same problem and it is due to the load sensor thinking that the load is not even. If it thinks the machine will be subject to excessive vibration it stops the spin progressively. I don't know how the machine checks for uneven load, there must be a vibration sensor, maybe it gets worn and needs replacing, but I suggest you redistribute the load and spin again. Make sure the machine is level and not rocking. Also have a look here http://electrolux.manualsonline.com/washerdryer/ew_1200_i/possible-causes-21.php Please rate my reply thank you.
Posted on Jan 05, 2011
6ya staff
SOURCE:
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Swt955sa simpson topload washers but wont spin
i would suspect the motor brushes or something related too the motor
silly question but you do have spin switched on
i dont know your specific machine
but most modern spin speed adjustment knobs
have a setting 'no spin'
ive fixed four last week same thing the wee old lady and three familys .. same issue spin simply switched off
Mar 09, 2015 | Simpson Washing Machines
Washing machine won't spin
hello check the pump first it has to drain before it spins if ok the other cause could be the module board this controls the motor speed also brushes on the motor can cause spin problems hope it helps
regards
shaun
May 24, 2011 | Kenmore Washing Machines
My washing machine is not spinning can someone plz help
hello check the pump first it has to pump water out before it spins if the pump is ok check the module board this control the motor speed if this ok the brushes on the motor can cause the motor not to spin hope it helps
regards
shaun
Mar 20, 2011 | Zanussi Washing Machines
Hello, My washing machine MW 6152W instuction guide can't find it and my washing machine is now on but doesn't spin at all for nearly 8 hours now. Please help me to get my washing mashine work.
hello check the pump first it has drain water out first before it spins if the pump is ok then check the module board this controls the motor speed if this ok the brushes on the motor can cause it not to spin hope it helps
regards
shaun
Mar 20, 2011 | Washing Machines
HOTPOINT AQUARIES WM63 , NO SPIN SPEED- MOTOR WORKS OK ON WASH, BRUSHES LOOK OK.
If the brushes are less than 3 or 4 mm long, then they need replacing.
If still no spin , but washes o/k, then the high speed part of the motor windings could be faulty, which entails replacing the motor.
Please rate my solution.
Thankyou
Jan 19, 2010 | Hotpoint Washing Machines
Operates correctly on all wash,rinse,soak cycles but does no spin
Check the door switch, if it's faulty the spin cycle will not work, but everything else will.
Apr 02, 2009 | Asko W6021 Front Load Washer
Error F 04
im not up to speed with the codes. BUT if you are able to open the door this suggests the bulk of the water has pumped away, so I suspect motor or belt problems. Can you hear the motor spinning when it should be? ie on spin cycle. If not suspect carbon brushes in motor, or even a broken/burned out wire to motor. Replace belt if broken
Oct 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Aug 19, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Electrolux EW1200i Front Load Washer / Dryer Logo
205 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
