Then the solution is simple-use Firewire cable to capture video into your laptop.This is the standard hardware set recognized by any OS and most Video Editing software.Simply plug in your cam to your computer via the cable.Your laptop should immediately "see" your cam.The rest is then easy.
Oops...forgot to ask the make&model of your laptop.If it does not have that firewire port built-in.Then you've got quite a trouble...
ive had my camcord for a while but not been able to use it much as when i record it is black cant see what im recording its still new in box every think else works is this a problem with this make!!!!!
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Haggai,
There's a problem on the CCD Imager Processor,it is located inside, exactly behind the lens,if you're not qualified tech.not try to open it,bring it to SSC (sony service center)
Fred Loja
