LG LS-L1210CL Mini Split Air Conditioner Logo
Posted on Jan 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer show E7 A/C - LG LS-L1210CL Mini Split Air Conditioner
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Jan 05, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953356
Points
6173
E-7. This is a communication error between the indoor andout door units.Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor.
1helpful
2answers
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
E7 error on my Treadmill
My treadmill doesn't have an incline/decline. It's beeping and showing E7 . I lost the safety key so thought it was that but I got a new one and it's still doing the same. I've looked to take the cover off but can't find no screws! HELP .
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
My nokia E7 phone's charging pin is loose connection.has the mother board damaged?
it is difficult to know, because you need to open device and check or show some oficial repairer
5helpful
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
29helpful
3answers
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
4helpful
When i start printer E 7 2 error messge is displaying
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
