Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I have cruzer micro 8gb i am fix into my computer usb sloat and usb light work but my computer no response in my coputer never found usb file and messeg hardwere install plzzzzzzz plzzzzzzzzzzzz help meeeeeeeeeeeeeeeeeeeee
Posted by pathanrageeb on
Anonymous
    Scholar:
  • 24 Answers
It sounds like your media is malfunctioning (controller issue).
Our company, LC Technology, is the only Sandisk-approved
data recovery company and we have been working on their products
for over 5 years. You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Sandisk with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Posted on Jan 12, 2011
Anonymous
    New Friend:
  • 17 Answers
First if possible try it on another computer, if it doesn't work on it then it's dead (However in my 15 years of I.T. i haven't seen one actually die yet) If it works on the other computer then you will just need to reinstall the usb software on your other computer.
Also if you have to many USB Peripherals in use then they may be hogging the power that your usb device needs to start
Posted on Jan 06, 2011
My 8gb sandisk cruzer does not light up anymore and is not recognized.
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 29, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Nov 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
Oct 20, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a sandisk cruzer, led continuously lights
I"ve seen a couple of these do this and the flash disc is broken and not working. Probably nothing you can do to fix it.
Sep 30, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Installation of Scandisk Cruzer Micro flash
Make sure your computer has the software to use USB 2.0
May 04, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Heating up and shutting down
it is due to viruses try kaspersky internet security 2009,panda antivirus,norton or mcafee
most likely kaspersky can fix it
Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Will not intialize.
just go to my computer find the driver that is your usb and right click.....propeties.....autoplay. then tell it what you want it to do... if there is no autoplay option then select file type.. this should fix it.
Mar 17, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer 8 gb micro usb not being recognized
Do you have another USB port you can use? Is this connected to a USB hub?
Jul 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
74 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
