EVERY failure code schematic i look at on maytag states that if your getting a f7 code then your keppad has failed or is stuck... make sure you turn breaker off for approx. 30 seconds and run your hand across touch pad firmly pressing down on all the keys... reset breaker and try again... if it still faults then you are going to have a bad touch pad... be warned though the touch pad does have a ribbon cable that connects to the control coard and it is possible it has shorted control/display board as well... hope this helps you out ...appliance servicer for 18 years
good luck
Testimonial: "Good Info, Thankyou"
