Disney Pix  Micro Digital Camera Logo
A
Anonymous Posted on Jan 05, 2011
Pictures won't load to computer says it needs drivers Installed the disc and it doesn't work.
Dou dou
Level 3:
Master:
  • Master 340 Answers
  • Posted on Jan 05, 2011
Dou dou
Master
Level 3:
Master:
Answers
340
Questions
0
Helped
55229
Points
1116
You need to Install the driver softer ware on the CD which comes with your camera before you what to load the pictures to your computer. For conveniently, you can use a card reader, and needn't driver. anything help?
1helpful
Windows 7 will not reckonize my fuji jx580
If you want to install Fujifilm software then you will need administrator privileges for your computer.
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
I have a Boggle Interactive disc WINDOWS 95, 99021, made by Hasbro and it will not load on to my new computer. It played ok on my old comp but won't load. In fact the comp. doesn't even act like it...
TRY DISABLING YOUR VIRUS PROTECTION FIRST...THEN INSERT YOUR DISK, GO TO SOFTWARE PROGRAMS, CLICK ON INSTALL NEW SOFTWARE...OR YOU CAN TRY LEAVING YOUR DISK IN AND RESTART YOUR COMPUTER, TO SEE IF IT WILL DETECT YOUR SOFTWARE...MORE THAN LIKELY YOU'LL HAVE TO DISABLE YOUR VIRUS PROTECTION FIRST, UNTILL YOUR ABLE TO INSTALL THE SOFTWARE.
DO NOT HAVE YOUR GAME HOOKED UP, UNTILL SOFTWARE IS INSTALLED.
REBOOT YOUR COMPUTER, WITH GAME HOOKED UP, SO THE COMPUTER CAN DETECT YOUR HARDWARE.
HOPE THIS HELPS!
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
I have a dell dimension 3000. I wiped the computer, installed OS disc, but it says FAIL every time I try to do anything with the utilities & drivers disc. I also have no internet because it won't...
Right click on My Computer>Manage>Device Manager>does your CD-ROM have a yellow ? or ! on it?
If so, then you somehow need to install a driver for your computer to recognize your drive. If you can get an external CD-ROM that connects to a USB port, maybe you can install the drivers that way. Once that CD-ROM is working, then you can get the drivers installed for your modem. Hope that helps!
Can i use my emachine recovery disk on my gateway after i install a new hard drive on my gateway?
No, you can't. (Well, it might be possible, but very unlikely, that it would work.) Recovery discs are made for specific machines. There are a couple of reasons why the discs for one system can't be used for another brand or model.
In addition to installing the operating system (Windows), recovery discs also include drivers for the machine's included hardware (video, sound, media card slots, etc.). The drivers on the recovery disc for an eMachines system won't have what a Gateway system needs, unless they were built using exactly the same motherboard and other parts, which would be quite unusual. If wrong hardware drivers are installed, Windows may not start and give you the famous "blue screen of death". Or Windows will start, then begin finding new hardware and asking you for drivers you won't have (although you could find them at the Gateway website). The discs also include the applications the manufacturer preloaded on the system. Some of these may not work and cause problems because of the hardware differences (a sound control program with the wrong sound hardware, for instance).
The other reason is that a restore disc also includes information that gets placed into Windows so the system comes up already activated and ready to go. Activation is based on information about the hardware configuration of the system, and yours won't be correct. Windows will see the this and you'll need to activate manually. If the Windows version on the eMachines recovery disc isn't exactly the same as the one on the Gateway, the product key on the computer won't work when you try activation.
Rather than try using the wrong recovery disc, see if you can borrow or download the installation disc for the Windows version specified on the product key sticker on the Gateway. Then you can do a clean new Windows installation and activate it using the product key. You can find the drivers your computer needs at Gateway's website as I mentioned before. It's more work than just running the recovery disc, but it will work. This does mean the system won't have any of the preloaded applications originally on the computer when you're finished. But this is not a bad thing.
Much of the preloaded stuff on a new computer is often called "bloatware", which you really don't need. It just slows the computer down, uses up Windows resources, and may be gathering information and sending it to sites behind your back. You can find good free programs to do anything originally installed and install only what you really need and want. Here are a few suggestions to get you started:
CD/DVD burning: CDBurnerXP
Antivirus: AVG, Avast!
Audio processing: Audacity
Image processing: GIMP
Office suite: OpenOffice
Good luck getting the system back up and running. Thanks for using Fixya!
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
1helpful
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Had computer viruses,laptop erased disc info,lost disc need to up load work pics,computer won,t recognize?e-mail [email protected]
You can always use a card reader to upload pictures....then you don't need any special software. b4161c2.jpg
Oct 20, 2010 • Cameras
Top Disney Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Disney Camera Expert? Answer questions, earn points and help others
