Follow the instructions on page 74 of the manual.
SOURCE: polaroid pdc 4055
Take batteries out- leave for an hours or more re insert batteries and follow set up procedure in the manual
SOURCE: Time & date
What could be happening is the you mother board is bad already. Usually digital cameras like computers use a button cell battery inside to keep the bios in memory or the board uses the installed batteries to keep the bios in memory but at a very slow power consuption rate. Everything comes down to pretty much a bad circuit somewhere that is causing memory lost and high consuption of battery power.
Also i've noticed that a lot of people with this camera is having the same problem. This called be because of mass production you all could have a bad batch. Meaning your cameras came off the assembly line around the same time.
SOURCE: polaroid digital camera a500
i cant get my vpc t-700 digital camera from saying no image i need to save my pictures thank you
SOURCE: Setting Date/Time on Polaroid a530
I contacted Polaroid help desk and they were clueless. They said there is no way to set the time after messing around with the camera for 10 minutes.
When you pull the photos off the camera it does record a date and time. I believe they forgot to add the option in the setup menu so you cannot get to it. I asked for them to send me a differant camera and the help desk rep laughed.
I guess thats what I get for buying a cheap camera.
SOURCE: polaroid a520 will not keep the date
You may want to set the factory defaults by going into the main maenu.
