Question about ION Audio Vinyl Recording Turntable
The needle is broken off can it be fixed for less then the turntable cost?
Posted by arielisaseni on
Grubhead
  • ION Audio Master
  • 5,700 Answers
Yes it can. On the head of the arm if you look carefully where the needle (to give it's correct name -stylus) is. What it fits into is a cartridge. If you can see letters or numbers on it that will be the type. If you put that into Google it should find it. You should find if it is possible to buy the stylus with or without the cartridge. Though it's often cheaper to buy both. The cartridge will either be screwed onto the head or just clipped on someway. You will find four wires attached to the cartridge. These will have to be removed if you have to replace the cartridge. Make a note of how each wire attaches to the cartridge. As long as you can get a cartridge to fit the headshell you can use any magnetic cartridge for the job. All you would need to do with a different cartridge is adjust the weight to apply the correct pressure to the stylus.
If the cartridge doesn't have any number etc on it, put the make/model number of the turntable into Google adding cartridge/stylus.
Posted on Jan 05, 2011
The turntable isn't turning on one of our units and the cassette player isn't working on another. Where can they be fixed? Just bought needles for both.
My turntable quit and I found out it had a broken drive belt. Mine was easy to get into but can't buy a new one They don't make mine any more. I suspect your player could have a broken belt as well. I put mine in the garbage. No parts and going to cost more than new to repair.
Oct 23, 2016 | Audio Players & Recorders
The needle arm won't lift and go to the record
Pull the turntable off the mount and look at the loading mechanism, I will bet you will find a broken piece.
Jul 01, 2016 | Audio Players & Recorders
Scratchy sound on turntable with mat om
One of two things. The deck has got a static problem. Perhaps caused by an earth connection problem.
Or you have a bad earth connection on the cartridge.
Dec 27, 2015 | Crosley Executive Portable USB Turntable
Need needle for bush RPA1 turntable
Hi, we have them in stock. Cheers John. Stylus City
Mar 02, 2014 | Bush RPA 1 Turntable
Hello i have a pioneer pl-300 turntable. i bought it used and it's been working fine until today. now the needle skips ahead on the record. i am VERY inept with technical knowledge of turntables i just...
if its skipping ahead Almost like the needle is just gliding across the Record. It means your needle is bent, dirty or broken, Take it off and look at it closely.
May 30, 2011 | Pioneer Audio Players & Recorders
Why wont my needle stay down on my record
The turntable might need some maintenance - sometimes the mechanical parts will freeze due to dried up lubrication. The arm which guides the needle may be stuck in a certain position. Tear it apart and lubricate the moving parts. Also, check the needle cartridge - it may be broken.
Jan 20, 2011 | Audio Players & Recorders
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Dan
Aug 11, 2009 | Numark ttUSB Turntable
Preamp seems to only play bass range
Your query incomplete. Please resubmit.
Dec 16, 2008 | Audio Technica AT-PL50 Turntable
Turntable
No way to fix these. Numark discontinued the parts for this model, in addition, it probably would have cost you more to repair than fix.
Junk em. Next time buy a package with Technics turntables in them. You won't regret it, and they hold their value over time.
I know Technics 1200s are not cheap, but with the money you just wasted on this package, you could have bought 1 Technic 1200.
- OPTiC
DJ Pro Audio
www.djproaudio.com
Mar 05, 2008 | Numark TT1520 Turntable
ION Audio Vinyl Recording Turntable Logo
230 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Tom Chichester
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
