Question about Razor E100 Electric Scooter
Razor scooter is charged but throttle wont engage motor
Posted by davewatras on
3 Related Answers
ROB
  • 858 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
Anonymous
SOURCE: razor electric scooter power light not lite but
have you checked the batteries to see if they have the correct voltage. i checked my bateries and they checked of at 13.5 volts and so i decided to check the motor well it was seized and found replacement motor for 27 dollors. http://www.monsterscooterparts.com/motors1.html
Posted on Aug 06, 2009
Anonymous
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
how did you fix the transistor? Can you send me the schematics. dgarbaty at hot mail dot com.
Posted on Apr 09, 2010
Why doesn't it go when I twist the throttle and I can't push it backwards?
These scooters have a speed controller system that will only power the motor if you get it moving about 5 mph. It won't start moving from a dead stop.
Apr 15, 2016 | Razor E300 Scooter
I have a razor 24volt electric scooter it's charged but I turn the throttle the motor don't turn but will if I jump a wire from battery to motor
it could be the control box. check under the scooter. the photo shows everything needed to make it run. throttle to control box/box to motor/
May 31, 2015 | Electric Toys
ALSO IF ANYONE HAS ANY TROUBLE WITH RAZOR SCOOTERS WITH GETTING THEM TO GO,IT CAN BE THE TENSIONER,WHEELS,CHAIN,MOTOR,BATTERY,CHARGER,CONTROL MODULE,RESET BUTTON,LIGHT SWITCH,AND THROTTLE.IF IT WORKS,BUT...
I purchased my batteries on E-bay. Selected the highest rated with a Square trader warranty. Delivery time was 4 days, new was was going to ask.
Delivered to my house for$21.00 with both batteries, charged and ran perfectly. Extended Warranty was also offered but declined.
Batteries still working great 6-months latter.
Mar 08, 2014 | Razor E300 Scooter
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
I have a razor e200. Nice physical condition. Garbage picked. Light on throttle lights up next to the 24V label. No power when throttle is open. No engine noise. power switch is on. reset button is...
Charge the batteries. If still no power than replace the batteries because they are dead. The batteries in the scooter need to be kept charged. If the scooter has not been charge in two weeks to a month and over. They are probably dead and need replacing. Find replacements at razor.com
Jul 31, 2010 | Razor E200/300 Electric Scooter Battery
Charges and light comes and sounds like it engages but does not move
in order for the scooter to go you must already be walking with the scooter. so hold down the throttle and start to push (kick) the scooter.
Jan 31, 2010 | Razor E100 Electric Scooters Red
Razor E100 Electric Scooter Logo
102 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Toy Expert? Answer questions, earn points and help others
