Question about HP Pavilion a6417c Desktop PC / Athlon 64 X2 4800+ 2.5 GHz / GeForce 6150SE nForce 430 /3
Do I need a network card to turn my PC wireless
graeme ian hunter
    Genius:
  • 1,288 Answers
If it does not already have one installed, yes you will, or you could opt for a USB network dongle
Posted on Jan 04, 2011
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Dell inspiron 6400 wireless capability turned off. need to find switch or function key combination
Hi, How do u do? You can easily turn it on by pressing Fn + F2.
have nice day. Babak
Mar 13, 2011 | Computers & Internet
To whom can help, The wireless is not working on my ASUS Eee PC 1000HA. It's working on every other laptop in my house so, it is turned on, it's just not working on my Eee PC 1000HA. Thank you, Dr.M.Seus
Right click the wireless icon in the lower right hand corner by your clock and click view available wireless networks. Then select configure advanced settings. Click on the wireless networks tab.
In the lower part of the screen select your wireless network and remove it. Reboot the laptop
Once back on, view available wireless networks again, double click yours and join it again. It may ask you for your password so make sure you have that handy.
Mar 01, 2011 | ASUS Eee PC 1000HA Notebook
M trying to activate my wireless connection for my acer x1200 do I need a disk or can I press certain buttons to activate the wireless
You should be able to see there might be an antenna on the back of your computer which is part of the wireless network adaptor. I checked the specification of your computer and did not see wireless card included. You may need to buy one internal wireless card or a USB wireless card to use wireless feature. You will need to install the driver and configure it to use a wireless access point on some of the wireless cards. Usually you can turn on wireless by using network connection or using the connect to item in the start menu if you are using Windows Vista.
Nov 12, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
Wireless router
You need a network card that is functioning to connect to anything.
If your network card in the desktop stops functioning, you will need to replace it (or, if it's built into the motherboard, add a card).
Unless you have a wireless card also installed, you cannot connect wirelessly.
Dec 19, 2009 | Dell OptiPlex GX260 PC Desktop
Has An Acer Travelmate 243LC laptop got a build-in Wireless?
The link below will take you to a page on the Acer Web site that shows the specs for this laptop. According to the specs, this laptop does not come with onboard wireless (if this feature were part of the system, it would be listed in the specs). Also, you can check Device Manager to see if you have a Wireless Adapter listed under Network Adapters. If you don't see any type of Wireless adapter listed then you'll definitely know that your laptop doesn't have it built in.
To access Device Manager:
Right-click My Computer
Click Properties
Click Manage
In the left navigation pane, click Device Manager.
In the larger window, scroll down the list to Network Adapters.
Expand the Network Adapters tree to see the installed adapters.
http://www.acersupport.com/notebook/html/tm243lc_specs.html
However, the specs do show that this laptop has 2 PC Card slots. These slots give you at least a couple of options for connecting to the Internet. You can buy an Air Card that is installed in one of the PC Card slots when you want to use it to access the Internet. My company used to provide Air Cards for laptop users through AT&T. The advantage is that you have an uninterrupted connection to the Internet no matter your location.
You can also buy a WiFi card that fits into a PC Card slot. This card will be your Wireless NIC (adapter) providing you with the means to set up connections to wireless networks. Linksys is a pretty good brand and fairly easy to install and support. After installation and configuration, you can pop the card in your PC Card slot anytime you want to connect to a Wireless network then remove it when it's no longer needed.
I hope this helps you connect wirelessly using your laptop. Please rate this solution and thanks for using Fixya.
Mar 28, 2009 | Acer TravelMate 243LC Notebook
No wireless connection
Hi you could try this...
On the problem PC, go into Control Panel, Internet and Network Connections, then select Network Connections.
You should see a wireless connection if you have a wireless card installed.
Right click the connection and select "enable".
this should activate the card
Jan 06, 2009 | Dell Precision T3400 375W 64bit (bwcw9z6...
Wireless switch
Although the wireless switch on your Acer does turn on/off your wireless card, you will also need to make sure that your operating system (Windows) has the wireless card enabled.
Do the following:
  1. Go to Control Panel (Start -> Control Panel)
  2. Double-click Network Connections
  3. Right-click on Wireless Network Connection / WLAN (you can tell it is disabled if the icon is greyed)
  4. Click on "Enable" (if you see Disable, your network is already enabled)
You should check the bottom-right-hand area of your screen (in the menu bar) for your wireless icon. If this is not appearing, you'll have to go into Network Connections again and do the following:
  1. Right-click on Wireless Network Connection (your wireless network adapter)
  2. Select Properties
  3. Click the checkbox that says "Show icon in notification area when connected"
  4. Now click on the Wireless Networks tab (at the top of this dialogue box)
  5. Scan for a network and connect to it.
Nov 25, 2008 | Acer Aspire 3610 Notebook
Wireless network card driver missing. I re-installed it and restarted the notebook a few times but still no change.
first unplug your system unit and remove the wireless card to system unit and then turn it on and install the driver and if finished turn off your computer put back the wireless network card and turn it on.
Nov 25, 2008 | Computers & Internet
Wireless G network card
uninstall the driver and restart PC, the PC should autodetect the hardware, slap in the cd that came with it and reinstall drivers. If that fail open device manager to see if their is any conflicts. If not the card went bad and youl need to get a new one.
Nov 10, 2007 | Belkin Desktop Card Network Adapter
HP Pavilion a6417c Desktop PC / Athlon 64 X2  4800+ 2.5 GHz  / GeForce 6150SE nForce 430 /3 Logo
50 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
