Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
Unit indicating different freq's than those I enter into the channels. Entered freq's will not hold, however, seems to be receiving entered freq's most of the time on scan. Just replaced the battery in back of unit with no change.
Posted by artroberts4 on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
This is not a CB problem. You are talking about a scanner. Sorry, I can't help you. Move your request to the proper category.
Posted on Jun 29, 2011
How do I puy the freq. in my bearcat210xlt?
Press the "Manual" button. Enter the frequency using the number keypad. Include the decimal when entering the number. Press "E" to set the number. Press "Manual" to move to the next channel and enter the next frequency. Continue until you have entered all of the frequencies
Read more : http://www.ehow.com/how_7198180_program-bearcat-210-scanner.html
Jan 16, 2015 | Radio Communications
I HAVE A UNIDEN BC80XL HAED HELD SCANER RADIO. MAYBE IM STIPID BUT I CANT GET IT PROGRAMED FOR ANY FREQ. i NEED SOME REALL HELP THANKS
Your first step is to compile a list of active frequencies in your area. You can find a very good database at:
www.RadioReference.com
Next, mark or highlight the frequencies that you want to program, making sure that they will work with your scanner. See your scanner manual for a list of covered frequency ranges. The BC80XLT will hold 50 frequencies.
Once you have the desired frequencies, you're ready to begin:
- Power the scanner ON.
- Press the MANUAL key.
- Enter the channel number that you want to program (01 - 50). If you're going to program the entire scanner for the first time, start with channel 01.
- Use the keypad to enter the desired frequency, including the decimal point (e.g., 146.075). Zeros at the end of the listed frequency need not be entered (e.g., 805.25000 should be entered as 805.25).
- Press the E key to save your program information.
- Press MANUAL to advance to the next channel, then start by entering the frequency.
More detailed instructions are in the factory manual. If you don't have a copy you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Listening in since the 60's
Feb 08, 2011 | Uniden BC60XLT-1 Handheld Scanner
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
NEED TO KNOW HOW TO RESET A PRESTIGE ELVATCE CAR ALARM
REPRIORITIZING A TRANSMITTER’S PROGRAMMING:
To reprogram a receiver channel with a different transmitter button once a code has been stored, there will be two options:
  1. Enter the transmitter program mode of the receiver channel to be reprogrammed. Using any unused button or combination of buttons, push out the stored code by pressing the unused button until a long chirp is heard, then repeat 3 additional times. After this, you can add any desired unused transmitter button. This action erases only that particular receiver channel, all other codes will remain stored.
  2. Enter the transmitter program mode. Using any transmitter button press and hold until a long chirp is heard. If a single chirp or multiple chirps, (up to 7 chirps), are heard, the unit is indicating that the transmitter has already been programmed elsewhere in the receiver. Release the transmitter button and within 5 seconds press and hold until a long chirp is heard. This action forces the unit to erase all stored codes of that transmitter.
The unit then exits the program mode the siren emits the program mode exit chirp pattern. All transmitter buttons for that transmitter must now be reprogrammed. Any other transmitter stored in the unit’s memory still remain operational. If the button is released and not pressed again within the 5 second period, no change in programming has been made to the receiver channel. The programmer can move onto a different channel or erase the transmitter codes as described in 1 above.
Regards, Martin @ http://www.lesscoelectronics.com
Sep 21, 2009 | APS20B Prestige Keyless Remote Alarm
Help me put new Frequencys in my scanner
Here is the link to all Uniden scanner manuals:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Also, you can find the frequencies for your area at www.radioreference.com.
May 20, 2009 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
Reset factory
Press hold. Go to the old frequencies. Press L/O twice. First press is a Temporary Lock Out and the second press is a permanent lock out. Then press hold again and enter the new freq and press "E yes" button to enter. To verify it is in your scanner, press HOLD/RESUME button, and you should see the new freq you just entered. Repeat all the above steps above for each new frequency.
Dec 21, 2008 | Uniden BCD996T Base Scanner
Programin the codes in a bc60xlt bearcat scanner
I am not familar with that model scanner but all the uniden radios I have used have direct freq entry......Hit manual button, select what channel you wish to enter it in, hit manual again. Enter the freq desired, then hit enter. That should enter the freq in that channel space. Hit enter again to go to the next channel for programming. Hope this helps.
Mar 19, 2008 | Radio Communications
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Reprograming
Hi, looks like page 24 of your manual covers that part.
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.Your scanner automatically rounds the entered frequency down to the closest valid frequency.For example, if you enter a frequency of 151.473, your scanner accepts it as151.470.
If you need a new manual, you can download it here.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
If your needing new freq's to use, you can go here and click on your state and county and get a list of freq's.
I hope this helps you with your question, let us know,, Mechanic
Feb 14, 2008 | Radio Shack Pro-82 Scanner
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
51 people viewed this question
Top Uniden Radio Communications Experts
Michael Thomas
Michael Thomas
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
