Question about M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof
My keystation 49e piano just quit working. i dont know why or how to fix it
Posted by donovanfrase on
2 Related Answers
Anonymous
SOURCE: Problem with "M-Audio 49e keystation"
The 49e has been a real pain--especially if you have previously used another M-audio controller on the same machine. I just spent 3 hours to get mine working on XP (with a Creative sound card). In summary--for my machine--Windows XP kept putting the old WDM driver back (vintage 2001), even though I installed the M-Audio. I had to finally use the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. After I go rid of the WDM drivers and replaced them with the 2 USB ones from M-Audio, my DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install. I don't know if this makes enough sense, but good luck.
Posted on Oct 24, 2007
Anonymous
SOURCE: M-Audio keystation 49e stopped working
JA user_offline.gif vbmenu_register("postmenu_31136", true); M-Audio Tech Support Join Date: Jun 2008 Location: Irwindale, CA Posts: 5,033 icon1.gif "I asked our repairs department and they said the problem is either the main board or the velocity board. You can order both boards from our repairs department and return the one that is not needed. The main board goes for $20 and the velocity board for $14. 626-610-2529, Mon - Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
Posted on Apr 28, 2009
1helpful
2answers
Keystation 61 key won't play
Most of these use conductive rubber pills that are pressed onto circuit board traces by the keys.
Clean the board AND the pills with 99% isoprophyl alcohol and QTips.
When I hit a key, it is off by just a millisecond. How can I calibrate my m audio keyboard?
who cares its just a millisecond and its just takes a while for it to load on the computer nobody actually counts the time it takes
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
4helpful
Cannot install driver for keystation 49e on Windows 2000 with Service pack 4
u cannot install the driver for keystation49e with service pack 4,becoz sp4 will not support for external audio device,uninstall the sp4 and the ninstall the driver
2answers
M-Audio Keyboard 49e disfunctions after some time
Sounds like it might be a power supply issue. Unless it is mains powered.
Try removing all other USB devised. If that doesn't work its worth try a Mains Powered USB hub.
5answers
Buy a Mac, Then you won't have that problem.
3helpful
2answers
M-audio 49e
Youve gone through the settings to make sure it is sending and your computer is receiving on the same midi channel?
Open Questions:
M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof Logo
Top M-Audio Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Lawrence Oravetz
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
