Question about Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Belkin F5D7230-4 ver 7002df works very bad! The connection keeps interrupting. What can I do?
Posted by larisutza_90 on
3 Related Answers
Anonymous
  • 2961 Answers
SOURCE: Low ID on emule when am using Belkin F5D7230-4 router
You need to find out what port Emule uses for sharing, then enter the port number in you routers Firewall Virtual Servers menu in the settings and enable your pc's ip address to accept inbound connections.
Posted on Jan 20, 2007
gewiz
Rob Hill
  • 1426 Answers
SOURCE: have blkin 54 - cant upload to my website, keeps interrupting me with belkin homepage
simply goto admin 192.168.2.1 or 192.168.1.1 or 192.168.0.1 you got to tell the router that you wish to kee p the port 21 open for ftp Firewall > Virtual Servers and add a entry using the port 21 and restart the router. Regards GeWiz
Posted on Jun 15, 2009
Christopher Thrash
  • 425 Answers
SOURCE: my belkin f5d7230-4 only keeps me connectected to
you need to set port forwarding see below.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For Linksys Router.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
For D-link router
You will see Network settings in the left hand side panel of the page.
Click on Network settings and go to the Advanced TAB at the top.
Now you will find the option. Pot Forwarding in the left hand panel.
Here you can open the ports on the router.
BELKIN wireless router
Click on Virtual Servers under Firewall in the menu on the left
Click Enabled. Type a general description of the application i.e.. Remote Desktop. Type the port(s) specified by the program manufacture for both of the Inbound port fields. Select TCP, UDP, or BOTH for the Type.Private IP address: Enter the IP address of the computer you want grant access too. Type the port(s) specified by the program manufacture for both of the Private port fields.Click the Apply Changes button.
NETGEAR Router.
Click on Port Triggering under Advanced menu.
Change the value of Port Triggering Timeout as 20 Click on Add Service. Specify a Unique/User Defined name under Service Name. Ex: Mails, VPN. Specify the Service User as Any (if all the computers in the network are port triggered or if a single computer on a network is port triggered specify the IP address of the computer). Select the Service Type of the port to be triggered
Ex: TCP . Specify the Trigger Port (The port to be triggered). Select the Connection Type of Inbound Connection. Specify the Starting and Ending Port for Inbound Connection. Click Apply to accept changes. Your router is now set up for port triggering..
http://www.youtube.com/watch?v=fYwd0YkXdY0&feature=related
Posted on Jan 20, 2011
Can i connect my xbox360 to belkin F5D8632-4a Ver 1
should be able to work with a cable or wirelessly.
Mar 06, 2011 | Belkin N1 Vision Router
Router keeps dropping signal. I have to constantly unplug it and restart it. Reset button doesn't work. Yes, mi Internet connection is OK, I've checked it with my phones and by connecting the computer...
Hi ,
I got your issue, Since your router keeps dropping the connection , the best fix is to update the firmware on the router. Here is the link,
http://en-us-support.belkin.com/app/answers/detail/a_id/306/session/L3NpZC9DRXppQW1maw%3D%3D/kw/f5d8236/r_id/166/sno/1
You have 4 different firmware version, select the appropriate version for Eg: If your version number of the router is ver:3000 then download v 3xxx and update the firmware on the router , that it will fix your issue.
With Regards,
Prema.
Nov 18, 2010 | Belkin F5D8236-4 Router
We have a nintendo dsixl. we also have a cisco n router that works fine with our hp laptop. we can not get the ds to pick up a signal or if it picks up a signal it is very weak and disconnects quickly....
If the internal wireless does not work there are a couple items to check. First make sure that the wireless router supports 802.11b, as routers that only broadcast in 802.11g or 802.11n may not be compatible. Then make sure that the DS is within proper range of a wireless router and has a signal strength of at least two bars. If trying to play a multi-player game, make sure that all DS systems are within 30 feet of each other, and that each DS has its own game card if needed. When trying to connect to a wireless router, also make sure that the correct encryption key is being used. The DS lite will also only work with WEP (Wired Encryption Protocol), because WPA (Wi-Fi Protected Access) is not supported. The website at the bottom of this guide is a link to Nintendo's Customer Service site that has information on how to configure your specific wireless router based on its manufacture and model number. If these steps do not work, the wireless card in the DS may need to be replaced. Additionally, Nintendo has found the following routers to have known compatibility issues.
Actiontec GT704-WG
Belkin F5D7231-4 ver 1102
Belkin F5D6231-4 ver 1000
Belkin F5D7230-4 ver 4000
D-Link DI-514 ver B1
D-Link DSL-G604T
SMC SMC2804WBR-G product code: 751.7412
The following link has information about properly configuring your specific WiFi router to work with the DS.
nintendo.com/consumer/wfc/en_...
Sep 16, 2010 | Nintendo DSi Matte Blue Console
My Belkin N1 (F5D8232 ver.1.0) reset's randomly
try upgrading the firmware. if it doesn;t help, the router is brick.
Sep 10, 2009 | Belkin N1 Vision Wireless Router
Earthlink mailbox will not send/receive mail while connected to the Belkin F5D7234-4 ver 3 router.
First, you need to call earthlink and ask port numbers used for incoming and outgoing mail traffic.
Next, you need to call Belkin for assistance on how to open these ports on the router. The router's firewall prohibits access to some of the application ports.
Jul 31, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Have blkin 54 - cant upload to my website, keeps interrupting me with belkin homepage
Apr 19, 2009 | Belkin (F5D8231-4) Wireless Router...
Need drivers for the belkin
have you checked the manufacture website
Jan 14, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin F5D7230-4 Kit (F5D7230V4SNPDQ) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Resolution IT Dubai
Resolution IT Dubai
Mike
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
