Question about Hitachi 42HDS69 42 in. Plasma Television
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
Anonymous
    Master:
  • 691 Answers
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Posted on Jan 04, 2011
Hitachi Ultravision tv model number: P50S602 When I turn it on the blue power button comes on and the sound comes on for about 2 seconds then the sound turns off and the blue light flashes three times...
Lights flashing is code talk .So call a TV repair guy and ask him good one will tell u what the light code means over phone cause he'll wanna sell u parts or get your business for service .
A black vertical line suddenly appeared on the right side of my hitachi 47 in fhd
probably there is a losse connection on the t-con board connector of your tv to repair it you need to open the enclosure of the tv try to reinforce the connector or you can replace the board to eliminate the error
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
2answers
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Hitachi 42HDS69 42 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
