Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch Logo
Posted on Jan 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Anonymous
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Jan 08, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
96
Questions
Helped
18823
Points
248
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Playstation 3 error code 80710723
That might be a problem due to the software update try this:
Forward the following ports to your PS3's IP
TCP:80, 443, 5223
UDP:3478-3479, 3658
Then disable UPNP in your router's settings.
Im been trying to download version 1.10 update software for Call Of Duty:Black Ops, and it simply wont let me download it, it goes until 6% downloaded and it fails. My error code is 80710723 and i've...
80710723 Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
You really might want to try creating the connections again on your PS3 system on the same modem/router you are using.
Just re-configure you connection settings and see if that helps.
Error 80710723 wont let me do update can you help
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658 or add PS3 to DMZ
What does error code 80710723 on COD World at War mean?
This error is caused by an issue with the ports of your router.
To solve this error :
On your router settings, open TCP port 80, port 443, port 5223 and UDP port 3478, port 3479, port 3658.
Disable the media server connection option found under the Network Settings menu option on the Playstation 3.
2answers
My ps3 gives me an error code 80710723 what shall i do
Hi sir
80710723 - error code
Error during download code is 80710723 whats that
Hello Mr .
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
1helpful
When downloading a system update it fails about 8% and gives the following error: 80710723
This might help
This is what I found.
"80710723
Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ"
you can do this buy
You will have to open ports on your router. You can check the manual or the router manufacturer's web site for help doing this.
Go to the "Settings" icon on your XMB then go to the very bottom "Network Settings". Once there go to "Settings and Connection Status List". It should be the first thing.
any probs let me know
6helpful
2answers
Keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
