Question about Dremel Variable - Speed Multipro Rotary Tool 395
Where can I get a flex shaft attachment (Model 225 T2)?
Posted by poulakos on
Mical Caterina
  • 3,400 Answers
Check w/ Home Depot and/or Lowes. If they don't stock they can get quickly
Posted on Jan 04, 2011
Replacing the spring in the Flex shaft attachment for Dremel Model 225
Use a piece of wire with a right angle hook on the end Push the wire down until it is inside the spring lever sideways and pull out.
Jan 22, 2013 | Dremel 225 Flex - Shaft
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Nov 06, 2012 | Dremel Variable - Speed Multipro Rotary...
I bought a Dremel Advantage 961 flex shaft quite some time ago and just tried to use it yesterday for the first time. I have installed the "Drive Nut" on the Advantage unit and then installed the...
sell it to me... im on my third one and cant find a new shaft......
i make mushroome sticks.....not happy at allllll....
dremel needs to make them again now.............im out of luck..
model 961 hasent been produced in10 years!!!!!!!!!!******..
still cant finf replacment parts.........t-bone..
Jul 31, 2011 | Dremel 225 Flex - Shaft
One end of the 225 t2 is a large receptacle with threads inside and a shaft below the threads.I have no adapter to connect it to the Dremel. The FlexiShaft came with the variable-speed Dremel but no...
To use the flex shaft, you need to remove the bit collet. Included in the kit is a nut looking item--mine is silver. It has a square end and screws on to the end of the dremel. It is simlar to the collet, but is slightly smaller. Then you place the square end of the flex shaft into the nut and screw the shaft on to the dremel.
Hope that helps
Jan 18, 2011 | Dremel 225 Multipro Flex - Shaft...
How do I attach the flex shaft. Given to me by someone who hasn't used in a while and I just purchased a Dremel rotary. She did not have a manual with it.
You remove the bit you were using and connect using existing collet, just tighten and go.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 04, 2010 | Dremel 225 Multipro Flex - Shaft...
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
I have lost instructions for dremel flex shaft attachment sue
There are no manuals I have found but I have a website and phone number for them the site is Dremel.com and the toll free number is 1-800-437-3635 you can use either one to get the manual you need.
Apr 18, 2009 | Dremel 225 Multipro Flex - Shaft...
Dremel Flex shaft attachment model 225
Dremel has an exchange program for the 225 Flex Shaft. Send your flex shaft and 17.90 and they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264 Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 09, 2008 | Dremel Variable - Speed Multipro Rotary...
Using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Nov 02, 2008 | Dremel Variable - Speed Multipro Rotary...
Flexshaft 225 T2
Do you have a 'nut' on the end, or just a wide open shaft (1/3 inch or so?)
You need a collet nut to tighten bits, and maybe collets of varying sizes also (not sure about this particular shaft).
Jun 16, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
233 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen
Van Allen
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
