I recently purchased a ST Regina Anniversary clock. I'm missing a part that attaches to the bottom of the clock where the pendulum pivots. It's looks to be a short extension of a post that would raise the pendulum to free it to turn. the store where I bought it is going out of business so no chance to return it. It keeps perfect time, just no turning pendulum. Any help much appreciated. GB
If your wall clock is running but the pendulum is not swinging, it may be due to a few potential issues with the pendulum mechanism. Here are some steps you can take to repair the pendulum mechanism:
Check the suspension spring: The suspension spring is a thin strip of metal that hangs down from the top of the clock and holds the pendulum in place. Check to see if the suspension spring is properly attached to the clock and if it is straight. If it is bent or damaged, it may need to be replaced.
Check the pendulum leader: The pendulum leader is the part of the clock that connects the pendulum to the clock's movement. Make sure that the pendulum leader is properly attached to the clock and that it is not bent or damaged.
Check the escapement: The escapement is the part of the clock that controls the swing of the pendulum. Make sure that the escapement is properly lubricated and that it is not damaged or jammed. If it is damaged or worn, it may need to be replaced.
Check the beat setting: The beat setting is the adjustment that ensures that the pendulum swings evenly. Make sure that the beat setting is properly adjusted by moving the pendulum to the left or right until it swings evenly.
Check the weights: If your clock has weights, make sure that they are properly attached and that they are not obstructed or damaged.
If you've tried these steps and the pendulum still isn't swinging, it may be best to contact a professional clock repair technician for further assistance. They will have the expertise and tools needed to properly diagnose and repair any issues with your clock's pendulum mechanism.
It sounds like the drive spring might be worn. A Good clock and watch specialist will be able to overhaul and service the clock for you. It might cost you a bit more money but if it is a family clock it could be worth it.
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
There is a very fine spring wire which makes the pendulum go, they often break when people touch or spin them. Replacements are available. Best to get it done professionally, suspension springs shouldn't cost too much
I had the same problem; I inherited a clock by that description with my office. I'm not sure if it would help you, but I was able to at least figure out the mechanics of the clock from this site: http://www.clockworks.com/cintro1.html
Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
