Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
SOURCE: Router Password forgotten
Pam, there is no way to retrieve just the password. You have to reset/reconfigure the router. Have you done router setups before? If not, I suggest you get someone to help you. If you want to try anyway, then have the printed manual next to you as you step through the sequence. Make sure you connect a PC to the router using an ethernet cable & confirm that the PC connects to the router. Admin is the user id. The factory default password is often "password" or "admin", but check on the manufacturer's site to be sure. Let me know if you have questions about any part of this.
SOURCE: ASUS rtn10 wirelles preoblem
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address
