Cars & Trucks Logo
Posted on Jan 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dash Gauges, tach, speedometer and radio dont work seconds after truck starts, dome light won't come on when door opens, and when using electrical door lock switch when the truck i sparked and turned off, driver door lock pops back up as if the key is still in the ignition.
Richard Smaill
Level 2:
Sergeant:
  • Ford Expert 403 Answers
  • Posted on Jan 03, 2011
Richard Smaill
Ford Expert
Level 2:
Sergeant:
Answers
403
Questions
0
Helped
118099
Points
962
Possible bcm you have a on board computer that tells you when doors are open lights are on also after turning key off you can listen to radio or open close windows for a limit of time then the bcm cuts off the power to everything if you are not sure check with dealer if they have problems with bcms body control module
No power to gauges or dash lights everything else works fine
Sounds like you blew a fuse in the fuse box should tell which fuse is what on most covers Good Luck Mike
Every thing works no gauges working
None of my gauges will work, but my turn signal indicators ...
www.americanautowire.com/.../none-of-my-gauges-will-work-but-my-tu...
None of my gauges will work, but my turn signal indicators, high beam ... As we've discussed previously, anything electrical needs a 12 volt feed and ground to work. ... 09/28/2015 There are a number of new products coming in Nov/Dec this ...
my gauges quit working - CarGurus
www.cargurus.com > Questions > Ford > F-250 Super Duty
CarGurusSep 21, 2013 - my gauges quit working - My odometer, speedometer, fuel, tach, trip, and ... I tried fixing the wire and had the same problem....so I replaced the shift lever and everything is back to ... no gauges will work in dashboard 1 answer.
No dash gauges, but dash lights - Car Forums and Automotive Chat ...
www.automotiveforums.com > ... > Dodge > Caravan ' Voyager
Feb 6, 2010 - The dash lights work fine, so does everything else. The dash gaugesjust don't work. This is something that has been an intermittent problem ...
All my gauges quit on my 2003 silverado the dash lights still work but none of the gauges move
Hi, this is a pretty common problem on these Silverado instrument clusters. We can definitely help you out with that. Click here to learn more about these Silverado instrument cluster problems: Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
1helpful
Battery indicator light comes on above idle RPM, gauges start fluctuating.
The first thing you need to know is what the alternator output is when this starts happening.
It could be a faulty connection in the wiring harness, or a bad ground connection, or a failing alternator.
Truck has a new battery. When you open the door the door and dome lights come on. when you put the key in the ignition and turn to run position the gauges come up. When you turn to the start position all...
dont think this is a battery cable problem but more like the igntion switch on the back of the steering lock ,try taking the shroud off and then use a meter to find the feed and then turn ignition on as the dash lights work then jump it across from the feed to the starter wire connection and if it works then you know you need to change the electrical switch .easy when you apply some logic
Dome light wont turn off. have to disconect the battery cable while it's unatended so it doesn't drain the battery.
Didn't list the year or model or car or truck or even the engine size or country it was sold new in. ( laws are different countries ) the cars and trucks are made with some differentes. the dome light can stayon because the dome switch is on. The headlight switch can be turned all the way or the dash gauges dimmer can be turned all the way up, On some model years you can turn it all the way down and the dome ligh will be out even with the door open. Some models don't turn off this way and you'll have to find the door switch thats not working. Sometimes going around and slamming each door will find the bad one as it'll blink the light or it might even start working again. If the car or truck has a hatch or trunk theirs a switch on some of them too the vans and suvs all do. The switches on some yaers ( current model till late 80's) the switch is incorperated into the door latch itself. Their hard to get too and it requires taking the inside door panel off to get to the latch and then some latches have to be removed to get to the switch thats screwed ( 1/4 turn) inti the side of the latch. The drivers door sets and resets sereravl things so just unplugging it won;t work. Removing the dome light fuse will fix it too but some radio functions might not work on certain models as the cruise control. Everythings intertwined, How much so depends on the year ands model.
1helpful
2answers
Lights dim and radio cuts out for a second when applying brakes - intermittenly. I can hear a slight high pitched noise.Yesterday on the freeway when I applied the brakes, the speedometer and tach went...
My degree is in electronics and I would be somewhat skeptical with that explanation. Define main relay? The relay has to control some electronic device like the dome light or turn signals. When the lights and radio cut out it sounds like a short circuit but that should have definitely blown a fuse. It is unlikely that it is an intermittent short and which is not fused because the insulation would quickly burn off the wires and start smoking. Therefore, I believe it would be more of an open circuit and would first check the battery for good clean connections. Next I would check the ground wire from the battery connection to the engine block and vehicle chassis.
3helpful
2answers
CLock, radio, dome lights, speedometer, keyless entry dont work
Check fuse 8 (10 amp fuse) in the under dash fuse panel. Make sure you have voltage to it on both sides of the fuse.This fuse feeds all of the items you listed.
2answers
Instrument Cluster Problem
I have a 1998 Jeep Grand Cherokee that had the same problems you describe.
I cured it by removing part of the dashboard and cleaning/checking all electrical connections.
Any black leads that connect to the metalwork .. they are earth wires. Check them for corrosion and as they are usually just held in place by a screw - undo that screw and retighten it. A 'bad earth' can cause the problems you describe.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
