Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
SOURCE: Coffee beans will not grind
Your machine will probably need service. The water will cause damage to the grinder burrs. I can send you instruction on how to clean out the grinder on a Vienna if you provide me will your email address. You can email me at [email protected]. You are not the first person to do this. These problems come in at least once a week. Hope this helps. Johnny
SOURCE: Coffee Beans Empty - but the hopper is full!
Caffeind...the problem is likely still some bean remnants stuck in a switch which is causing the problem. Get some newspaper and open it up on a flat surface. Invert the grinder and give it a couple of thumps on the newspaper. The chips should loosen up and fix it. Remember, beans are both sharp in shape and oily in makeup...perfect for getting stuck.
SOURCE: Miele CVA615 remove coffee bean dispenser?
their is a plastic screw below the bean dispenser .once unscrewed you will remove the dispenser
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
