Question about Philips Televison & Video
I have an older 42" philips tv model 42pf9966/37.
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
Posted on Mar 23, 2008
Anonymous
  • 19 Answers
SOURCE: my philips 42 inch plasma
Hi. Try, in back yours tv on left side of the power corde connector have on hole, inside of this hole have one main switch, using one insulated stick and sheck if this switch is off ( may be not ) but try. If you heva esperience take out the back cover and check the fuse on power board. Good lock
Posted on Jan 29, 2009
Anonymous
  • 6 Answers
SOURCE: NO POWER ON PHILIPS 42PF9966/37
I had the same problem with a philips 42FD9932 and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
Anonymous
  • 44 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Anonymous
  • 11 Answers
SOURCE: no picture, just sound, blown y buffer board twice1
a4.. there are 2 of them, upper and lower buffer boards.. they control the top and lower half of screen devided horizontally, i have had many run ins with these sets. and usually the buffer boards arent cheap.
they plug into the ysus( y sustain).. its possible your y sustain is blowing the buffer moduals because one of its i.c.'s under the heatsink has popped on ya.. effectively creating a short that blows the buffer boards.
remove the buffer boards, turn tv on... feel the 2 silver heat sinks on that y sustain( beware dont zap urself.. just the tip of your finger on the heatsinks)
you may find that one is cold and one is hot...if so, you need a new y sus and probably to replace the buffer boards the a4 upper and a4 lower.
If you get a new ysus.. plug the a4 upper and lowers into it, look at your picture.. if ur missing the top half the top buffer is blown or lower half the bottom buffer is blown. or..no picture they could both be blown..an easy way to tell if u have no picture to diagnose is..touch the heatsinks that sit over the chips on the buffers..if they are red hot.. they are bad and shorted internally.
Posted on Dec 11, 2009
Philips TV model 37PFL5322D/37 Colors just became oversaturated and I need help diagnosing the problem?
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 25, 2016 | Philips Televison & Video
Toshiba 42HP66 42 in. LCD Television Color Problem
se cablesdry joints or loooossibly the ribbon cables check for
Sep 19, 2012 | Toshiba 42HP66 42 in. LCD Television
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
Display Screen goes black
Right Click on Desktop
select Properties
select the Scree Saver tab
Click on the Power Button which is on the right side
select the power schemes
In that select the power schemes options and choose "Never" for turn off monitor, turn off hard disk and system stand by
click on
Apply
Repeat the above step for each option in "Power Schemes"
then click on ok
Feb 15, 2008 | Compaq Presario 1200,1600, Series CD...
Televison & Video Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
