SOURCE: Transfer of video from Panasonic NV-GS50 tape to computer
You will need a firewire card in your PC and firewire cable to connect your camera to the PC. you will also need a software like Windows movie maker which can help you to transfer videos from your camera to the PC.
SOURCE: panasonic nv-ds60
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
SOURCE: USB drivers for panasonic nv-gs11 gc
I have a software for that model.... NV-GS11GC it work only on Window XP,Me,98SE
SOURCE: How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
