Maxtor One Touch (RBAY080B0USR) Hard Drive Logo
Question about Maxtor One Touch (RBAY080B0USR) Hard Drive
IO Device Error
Hard Drive was working fine until today - no changes. I have a Maxtor 200GB One Touch. When I try to access the drive, I get the following error: L:/ is not accessible. The request could not be performed because of an I/O device error. I have tried a different USB cable and tried other USB ports and got the same result. Any help is appreciated.
Thanks
Posted by LeannWyz on
  • gregww Jul 10, 2008
    I am experiencing the same issue. I get the same message on my laptop and desktop PC's. Was working fine previously.
Paul Chapman
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
My Maxtor died like this. The disk was OK, it was the electronics that blew. I bought a new empty disk drive box and fitted the disk drive and fixed it. Years later the disk still works in the replacement box and power supply. I got my files and data back with the disk drive in the new box. The size of that disk looks small today. It may be Parallel (PATA) and you need a PATA box, that is harder to find as obsolete. You need to try the disk first in another drive holder.
So PATA and SATA??? Look here and read up about it with pictures too:
https://askleo.com/whats_the_difference_between_sata_and_pata_and_ide/
An external disk unit has three main parts.
1. The disk drive.
2. The electronics box.
3. The power supply.
Posted on Sep 08, 2017
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: maxtor external hard drive is not accessable
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Posted on Mar 30, 2007
Anonymous
  • 116 Answers
SOURCE: Device not working
Most of the time when you get error messages like this it is due too drivers. Now in order to determine this issue I need to know what type of computer you have, OS installed on it, how old the PC etc. Please advise!
Posted on Nov 26, 2007
Anonymous
  • 16 Answers
SOURCE: maxtor password protection
I have seen this one before. You need to reinstall the Maxtor software and reset the encryption - if you do not have CD you can get the software online at:
http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Posted on Feb 09, 2008
Anonymous
  • 143 Answers
SOURCE: Maxtor one touch software
John, try this link and see if it is indeed and newer version than what you currently have: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Retrospect_Express_HD_Update_for_Maxtor_OneTouch-FR&vgnextoid=f0ce8b9c4a8ff010VgnVCM100000dd04090aRCRD
Hope this works out.
Posted on May 13, 2008
Anonymous
SOURCE: How Do You Open a Maxtor 3200 500 gb case?
How to open the enclosure You will need a long flat piece of metal.
On the sides of the enclosure are small slits.
If you look in the slits diagonally you will see a metal tab.
Slide the metal tabs about 1/4" towards the ends of the case. (there are 4 slides one on each corner)
The case will now open freely.
Posted on Dec 14, 2008
My Maxtor 200GB external HD is not showing up on my Mac G4. I've tried USB & Firewire connections. Restarted the Maxtor then computer. Restarted computer, then Maxtor No good. Thanks for your...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
1helpful
2answers
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Maxtor One Touch III 160GB is not accessible - corrupted or ...
i had the same problem, i have removed the hdd cover and manually rotated the disc few times, it worked for 20-30 minutes, but it was enough to recover my data
Maxtor 3200 personal 200gb drive external
If you did in fact change the partioning structure then the only recourse is to send the drive to a data recovery center. If the drive is running they should be able to recover the data.
Computer won't acknowledge new drive as master
press delete or F2 when you turn on your pc go into setup and change the boot sequence.
MAXTOR ONE TOUCH 4 MINI
Try it in another computer if you have one. Or...try it in another USB port on your desktop PC. I would see if it appears in the device manager. If so, and you don't get a drive letter, try running
'diskmgmt.msc' and looking to see if the drive pops up under available drives.
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Top Maxtor Computers & Internet Experts
Mehandi Husain ...
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
