Hi
the problem sounds like either the fuel relay, or wire4s coming from the fuel pump to the fuse box.
the relay is most probable as when you turn the electro magnet inside may sway from side to side if faulty. You will have to locate the position of the fuel pump and trace the wires up to the fuse box if the relay is not at fault.
Hope this helps if you need more info get back to me
Regards
Dan
Testimonial: "thankyou!! now i just need to locate the fuel pump relay..."
If the fuse consistently blows when making left turns you most likely have a wire somewhere ground that fuse circuit. Check the interior Fuse box locations. If you have added an alarm package, changed the Radio or Stereo amplifier circuit to the vehicle those are the most likely source of your short. You should also check the power distribution box under the hood if you have added an Alarm or Stereo amplifier to the vehicle as it is common to tap power circuits in that area as well.
