Question about Panasonic Lumix DMC-LC20 Digital Camera
DMC-LC20 Panasonic camera
I have a DMC-LC Panasonic camera. I put new batteries in it and turn it on. It will immediately shut down. The camera is sensing the batteries are low and shutting down.
What is the solution. I don't want to send it in for repair because its older and not worth the repair charge.
Is there something I can do to adjust the sensor that tells the camera to shut down when the battery is low.
I'm sure its probably out of adjustment.
S. D. Franklin
Posted by stevnlinda on
  • ezryder Nov 07, 2008
    Is there any way someone can help me figure a way to fix the sensor on my camera. It senses the battery is dead but it is brand new.
4 Related Answers
Anonymous
  • 246 Answers
SOURCE: says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
Posted on May 19, 2009
Anonymous
SOURCE: hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Posted on Mar 30, 2008
Anonymous
  • 3 Answers
SOURCE: I have a Panasonic DMC-LZ7 camera. I have
My DMC-LZ7 started having the same "please replace batteries" error a few weeks ago (bought in 2007). It only seems to happen with my NiMH rechargables, though they test as full-strength with a cheap battery tester. Alkalines don't cause the error and I haven't tried Oxyride (ZR6) batteries yet.
The camera has two battery-type settings (Alkaline/NiMH
Posted on Oct 25, 2010
Ty Price
  • 11967 Answers
SOURCE: Panasonic DMC FX01 with new battery still won't turn on?
If your panasonic camera uses a panasonic battery and you try to use a different brand equivalent battery, some panasonics will not work. Could that be your problem?
Posted on Nov 11, 2011
My DMC-FZ20 turns on but has no image in viewfinder or screen.
I never experienced anything like that with my old FZ20 but with experiences in other cameras I've found a nice, easy way of fixing things tends to be a "hard reboot" I think it's called. Turn the camera on, then remove the battery while it's still on causing the camera to shut down due to power failure. Put the battery back in and IME, all should be well.
Mar 03, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
Cannot format a maxwell class 2 4 gb card for my lumix dmc-lc33
The DMC-LC33 is designed to work with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While it fits into the slot it will not work. You need to use SD cards, 2GB and smaller.
Aug 24, 2010 | Panasonic Lumix DMC-LC20 Digital Camera
Camera shows batteries need replacing after putting in fresh ones
Try cleaning the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol. If the sticky coke got inside the camera, it will only get worse as the phosphoric acid does more damage.
Dec 08, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Lumix DMC-FX33 turns itself off
The message appears when force has been applied to the lens. You will probably need service.
Aug 13, 2009 | Panasonic DMC-FX33 Silver Digital Camera
Memory card is locked
Make sure taht the write protect notche of the device found on the side part of the card is on.
Alex
Jul 18, 2009 | Panasonic Lumix DMC-LC20 Digital Camera
Panasonic DMC LZ5 shutting down continuously
Krishna sometimes the software in the camera get lost how I do not know. When you pass through metal detectors it can happen. If I put mine down on the car hood the fields of electricity under the hood will cause it not to work. Remove the batteries and wait at least a couple of minutes and put fresh ones or strongly recharged ones back in and it should stop the problem. You batteries could be at fault as well, if they are weak it will cause the same problem
Jul 16, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
Problem with LCD
I have encountered this problem before, but with a different camera. Usually when you have a problem with horizontal lines that change over time, the lcd is not the issue. It's usually the data that is sent to the issue that is the problem. I ended up buying a broken camera of the same type from someone and switched out a circuit board. I never had much of a problem after that.
Jan 20, 2006 | Panasonic Lumix DMC-LC20 Digital Camera
Camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 31, 2005 | Panasonic Lumix DMC-LC20 Digital Camera
Panasonic Lumix DMC-LC20 Digital Camera Logo
Top Panasonic Cameras Experts
STEVE
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
