If you are facing problem in Your HP Pavilion laptop like startup issue, hangs up then call HP pavilion Notebook Customer Care number 1-888-687-4491 toll-free solution.
1 8886874491 HP Pavilion Gaming Laptop Tech Support Phone Number
There is no highspeed wifi. but yes 3/4g.
dont you mean you have wifi router
to connect you MUST match it, not husbands CPU.
the router broadcasts a wifi SSID, name
you click that and match what the router wants.
such is WPA2
and a pass phrase.
if you old A1240 is set to wep only or is so old it cant do WPA/2
then it fails.
I have no idea what WIFI card is your old PC.
and that matters big time.
what is best is login to the router and read what it wants
them may your pC do that.
I warn you the most old wifi cards are useless.
buy a WPA2 card (or usb wifi dongle new)
NO OS stated by you is this the virus magnet XP?
it will not interfere with HUSbands computer.
it will move to unused channels, auto, if set that way as it should.
SOURCE: WRONG RESTORE CD IN HP PAVILION A1330N
Alright, if I understand you...You possibly lost the original operating system disc for your HP Pavilion, and your daughter used a Windows XP restore disc, and now it is asking you to register the software?
AND you also lost the set-up software for your Internet provider?
SOURCE: Tried to install sp37394 on my HP amd processor
You can try installing SP3 in safe mode, so that It doesn't conflict with any application software.
It should get installed successfully and problems should be fixed.
(Restart PC and keep tapping F8 to get advanced menu options and choose safe mode from there)
Let me know if you need any more help !
Thanks !
SOURCE: I Have just been given a hp dc7600. I have it all
USB 'dongle' for wireless reception (the gizzy that recieves wirelessly) No, your dc7600 hasn't any built in wireless. Microcenter.com or another retailer in your area will have what you need, including software and instructions for that device. Of course, like you said, you could always hard wire it, if you don't mind running cable??????
SOURCE: my hp pavilion a1330n computer freezes on the HP
the dreaded Blue-Screen of death.
Usually caused by:- Ram Failure ( memory Modules )
CPU Failure ( Processor Failure )
Hard-Disk faulty, not spinning et,c.
Cmos battery fault.
Missing/deleted/corrupted operating System files.
Possible Solutions:- remove cmos battery, from Motherboard for 10 seconds and replace. ( eliminates cmos/bios errors )
remove 1 stick of Memory ( Ram ) and test individually ( eliminates 1 or More Faulty sticks Of memory Or Slots )
remove, CPU Fan/heatsink, remove CPU and re-seat, re-grease with Artic-Silver or similar ( thermal-Compound ) replace heatsink/Fan. test.
Hope this points you towards a Sucessful repair.
Mike @ Compurepair. No-Links No-Nonsense Just Good Practical Advise :-)
SOURCE: Hello, I just bought a HP Pavilion P6000 series.
Hi, I would contact the store and ask them what they set their password to. Without a restore or windows disk you won't be able to reset it to factory condition or reformat and reinstall windows. They should be able to give you the password and from there you can get in and change the password etc.
Thank you,
Lee
