SOURCE: Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
SOURCE: no sound on play back
There is a program that does it. Do not despair. I had the same problem and eventually found a prgram to do it. I am just trying now to find the program again because I need to use it for capturing. I will post back when I have the name of it. The problem apparently is that the camcorder doesn't process the 12bit audio properly and although it says that it is cdapturing in 16BIT, it is infact not. Anyways. I'll post back
SOURCE: Har en nyköpt ML-1640 som använts vid ca
>> Have a his newly bought ML-1640 used for about 50 prints. >> The problem is that suddenly stuck a paper written nearly finished, >> and the red light began to shine. >> The red light Must visa green normally. >> Tips on what the error is desired. A part of a piece of paper is jammed somewhere along the "path" that the paper must travel. Take the printer to a certified technician, and have them repair it. Perhaps, the "warranty" will pay for the repairs, or will provide a replacement ???
SOURCE: i need to find a
http://www.amazon.co.uk/Ex-Pro-Samsung-iLink-VP-D10-VP-D55-VP-D70/dp/B000QZZZ0O
I believe this is what you need.
