Question about Robotoolz Laser Level With Simultaneous Plumb + Square
I own a Porter Cable Self-leveling tool, model RT-5250-1. The unit was dropped and the top portion has been knocked off. I called about a year ago to get it fixed and they said to send the unit in along w/ $180. for repairs. Can I still do this, has the cost changed, what is the address and do I need some type of shipping number. Thanks
3 Related Answers
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: Need a RT-5250-1 Users Manual
Try freemanuals.com for your needs here
Posted on Apr 04, 2010
Anonymous
  • 677 Answers
SOURCE: Porter Cable was sold to Bosch, I called Bosch but
Here is a website of a company that repairs :
www.prontotech.com
Posted on Feb 05, 2010
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: i have an rt-5250-1 self
If the directions are not real clear as you say, then you should call the manufacturer to get tech support. I will send you a link to there site and phone #.
http://www.toolauthority.com/RoboToolz-RT-5250-2XPK.html
Good Luck!
Jim
Posted on Sep 13, 2010
How do I calibrate porter cable laser RT-7510-3 laser light works but stuck out of level
The handhelds are not meant to be calibrated, recycle properly and invest in a PLS3 or PLS5, they have a 3 year exchange warranty: https://www.plslaser.com/pls-best-class-warranty/
1helpful
2answers
I need my Unit rebuilt, unit was knocked over and the bearings fell out.Can this be done?
Unfortunately no. Nothing you do will make this accurate again. These are throw away lasers.
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
1helpful
2answers
Dropped rt7210-1 bearings out laser and drive ok
Dropped my robolaser RT7210-1 and the bearings came out.
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
1helpful
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
3helpful
2answers
The red beam on my laser won't show outdoors?
Check for a lint ball or a small piece of debris in the lens area. The smallest piece of anything will knock the brightness down. New batteries would be the only other thing I would think of.
Robotoolz Laser Level With Simultaneous Plumb + Square Logo
Top Robotoolz Measuring Tools & Sensors Experts
ADMIN Canada
ADMIN Canada
ray gallant
 Mikey
Mikey
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
