Question about Sharp LC-15AV7U 15 in. LCD Television
I have the Sharp LC-15AV7U, and suddenly, when I turn the TV on, the screen flickers, goes black (except a 1" line across the bottom), and no sound. Attached to satellite cable box, which I hooked up to another TV and works fine. I realize it's not that expensive to replace, but has been such a good television, I hate to throw it away if maybe a minor problem. Any suggestions?
Posted by Headlamp on
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
Anonymous
  • 208 Answers
SOURCE: Sharp aquos lcd screen goes blank
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
Anonymous
SOURCE: SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Posted on Jul 09, 2008
Anonymous
  • 14 Answers
SOURCE: green vertical lines
Possibly needs a new control circuit board or lcd panel
Posted on Jul 25, 2008
Anonymous
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
I have an old Sharp Model # 27A-S100 I have a Black Line running across the bottom of my screen from left to right 22 1/2" length and 3 1/4" in height
If this line does not go all the way across the screen then I will bet you this is an easy fix. Press the menu button on the remote control. The menu will hopefully show up over-top the black. Search your menu for the closed caption setting (usually under audio settings menu) and turn closed caption OFF. Hopefully this fixes your issue. Cheers.
Apr 24, 2011 | Sharp 27N-S100 27" TV
Evry morning at 8am a black box appears and a web
Check your closed caption settings via the on screen menu, if on, turn off.
Nov 06, 2009 | Sharp LC-15AV7U 15 in. LCD Television
LCD screen
most of the time when you see this it is your lcd panel that bad but it could be inverter. cost converter is around 395 on up and if it is lcd panel not worth fixing. I would call local tv shop ask them how much they charge for estimate . or ask them price on inverter or lcd panel replacement.
Thamks doctor video
May 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Sharp LC-15AV7U 15 in. LCD Television Logo
75 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
