Question about Home
I just purchased the Danco 52406 Shower W/Frame Add-On and wanted to install an different shower head...the Danco fixture is 3/8 and most heads are 1/2". I took the instructions with me to the local Lowes store and now, I cannot find them! Can I find the instuctions on-lins somewhere? Thank you Tim Husband
Posted by thusband761 on
mrbill99
    New Friend:
  • 5 Answers
I would try to find a 3/8 to 1/2 NPT adaptor on Amazon.
If Danco has a website, it's likely that the instructions for your model are available in the support section of the website.
Posted on Dec 01, 2017
5 Related Answers
Anonymous
  • 1605 Answers
SOURCE: shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Posted on Jan 13, 2009
Bill Johnson
  • 306 Answers
SOURCE: 1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Posted on Jul 27, 2009
Anonymous
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
Anonymous
  • 561 Answers
SOURCE: freehander leaks at shower heads
Hi
Thank you for your query
If you just grab the showerhead with one hand and then unscrew anticlockwise the pipe underneath it should just screw off, once this has been done simply replace the O ring and rescrew
I hope this has been useful
Posted on Mar 15, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
I want to install a new shwer head fixture. I am having difficulty removing the ball joint adapter. any ideas?
You have to remove the whole pipe going into the wall, the ball is not seperate. Use a pipe wrench or something similar to remove it. A new showerhead pipe needs teflon tape wrapped clockwise on the threads and screwed into the fitting inside the wall. Now you can install any shower head you want.
Jul 26, 2011 | Price Pfister 15 Series, Bell Shower Head...
Water comes out of the spout and shower head when I want to shower. This is after I replaced all the stems with new ones
The gate or bypass put of the tub spout is not stopping all of the water from coming out of it so that means it is not diverting all of the water to the shower head. The tube spout is not made for rebuilding in most cases but you could take it off and look for some sort of debris that may be causing this to happen.
Feb 11, 2011 | Danco Faucet Stem
I bought a Danco 3H-10H/C, Hot/Cold stem. The problem is, it seems to be setup for hot (clockwise closes the valve, counter clockwise closes it). Is it reversable? Or is it not really a hot/cold...
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Jul 18, 2010 | Danco Faucet Stem
My husband and I had a new house built and the plumber installed a rain shower head above the shower and a normal shower head. There is only one valve to turn the shower on and when i do water comes from...
There is a shut off valve that will screw onto the shower head extension pipe. It would fit on the pipe and then the shower head will screw back onto it.
Lowes or Home Depot should have them. Here is link to show you what to look for.
http://www.amazon.com/Danco-89171-Shut-Off-Shower-Chrome/dp/B000JFNPJE
I hope this helps.
Jun 22, 2010 | Plumbing
Shower drips while bath faucet is running
THIS PROBLEM IS DUE TO, POOR INSTALLATION,,,, THE ONLY SOLUTION IS TO ADD A SMALL VALVE IN BETWEEN THE SHOWER HEAD AND THE WALL,,, WHICH DEPENDING ON THE FINISH OF THE FIXTURE, ONLY COSTS ABOUT 15 DOLLARS AND IS VERY EASY TO DUE.... MAKE SURE WHEN PURCHASING THE VALVE THAT IT WORKS,,,,, BY TURNING IT TO THE "OFF" POSITION AND BLOWING INTO IT,,,, IF NO AIR ESCAPES IT IS GOOD...
Dec 28, 2009 | Banner Plumbing
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Shower head leaks water when water is turned on
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
62 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
