SOURCE: Samsung HLT5076SX XAA turned itself off. Two
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
SOURCE: how do I install the
The manual for the TV usually has the instructions. You can find many Samsung manuals on their website (samsung.com). The bulb replacement is easy enough to do it yourself. You need a Phillips screw driver and a lint free cloth to handle the new lamp. Turn off and unplug the TV. Wait ~30 minutes after turning off the TV before starting.
Usually you need to remove one Phillips screw to take off the lamp cover. Then loosen two additional screws and pull the lamp housing out by the handle. If your new lamp came with the housing, just swap. Otherwise (some OEM lamps), you need to remove 6 more screws to exchange the lamps (these have nuts that are only hand tight). Make sure not to mix up the old and new lamps and store the old one in a safe place until you can dispose of it.
Then reverse the steps. If the cover is not properly secured the TV will not come on.
I hope this helps.
SOURCE: user manual for samsung tv model number hlr4667wx/xaa
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://downloadcenter.samsung.com/content/UM/201105/20110502090121225/20050902121438187_BP68-00469A-02Eng_20110502.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you Branden.
Good luck and take care.
Joe.
