Question about Sharp Cell Phones
I have a Sharp SPC502 atmoic clock/weather station. No matter what I do I cannot get the outside temp/humidy to show up on the main station. Have tried changing channels, different alignments, resetting. Any other suggestions? Thank you.
Posted by mlpatton09 on
  • 2 more comments
  • s3hampton
    s3hampton Apr 24, 2012
    To reset the Sharp SPC502 weather station:
    1. Remove batteries, or RESET both units
    2. Reset the remote transmitter FIRST
    3. Reset the base unit NEXT
    4. Set the base unit's channel to match the remote (Tap the UP ARROW KEY)
    5. WAIT until the remote temperature shows on base unit <=(Important!)
    6. AFTER the temperature shows up in the base unit, set the time zone, etc.
    7. Set time by pressing MODE key for several seconds to enter the SET MODE
    8. Use UP, DOWN ARROW buttons to shift the numbers or selections
    9. Tap the MODE key to advance to the next settable item, then set as needed
    10. Continue through items; Flashing items will stop at the end of the items
  • s3hampton
  • Thomas forster Nov 14, 2012
    Very helpfull everything now good.
  • athaswd
    athaswd Dec 11, 2012
    Presumed the unit was a goner because resetting and removing the batteries wasn't fixing the problem. You tip to WAIT was the difference and all is fine again. Unit isn't that old so I wasn't looking forward to spending money on another. Great tip! Thanks.
Anonymous
    New Friend:
Try pushing the reset button on the inside of the battery compartment of the remote unit then push the reset button on the back of the main unit (you'll need a paperclip or tooth pick to push the buttons). If that fails I'd start from scratch by removing the batteries from both the remote unit and the main unit then replace the batteries to the remote unit first and push reset, then replace the batteries to the main unit and if necessary push the reset button on the main unit too. Hope this helps.
Posted on Jan 02, 2011
  • 4 more comments
  • Melody Burch Nov 05, 2011
    I had the same problem, no matter what I did worked except for this...Take out the batteries from the remote and the base unit. Then press the reset button on both AFTER the batteries are out. This should reset it.
  • techsuppo989
    techsuppo989 Oct 28, 2012
    This worked for me also on 10/28/2012!
  • fordsa2s
    fordsa2s Nov 11, 2012
    me too! thanks!
  • jdodds5322
    jdodds5322 Jan 27, 2013
    This worked for me. Thanks
  • arlandb
    arlandb Dec 19, 2013
    this worked for me too. thanks
  • Eric Badofsky
    Eric Badofsky May 23, 2014
    Worked for me, too -- thank you!
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
The outside temp is not displaying
If the clock uses a remote temperature transmitter, you may need to replace batteries.
Jan 12, 2013 | Sharp Atomic Weather Station Alarm Clock...
How do i change language to english on sharp spc502 weather station
get the instruction manual fro HERE and change as you desire
Jan 08, 2013 | Computers & Internet
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
No longer shows temp (indoor or out) or weather. Outside unit is still working and showing temp.
Mine did the same thing. I just had to replace the batteries in the main unit and it is working again. Good luck!
May 22, 2011 | Leeds 805058 High Sierra Tahoe InOutdoor...
Cannot get the outside temp to respond on a WS9047U-IT
Bring the outdoor sensor indoors. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the outdoor sensor. Put the batteries back in the main unit. DO NOT PRESS ANY BUTTONS. Wait 10 minutes or until the outdoor temperature shows. Once the temperature shows you may use the buttons to set the clock, etc. If it does not show after 10 minutes, then try again.
Jan 07, 2011 | La Crosse Measuring Tools & Sensors
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
How to reset a Seth thomas weather station wall clock
what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
Cell Phones Logo
7,904 people viewed this question
Top Sharp Cell Phones Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
