Watches Logo
Question about Watches
I have a AW60448W stopwatch that I can't get the alarms to turn off.
Posted by sandycarm on
Hoppy3927
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: [email protected] if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Posted on Jun 14, 2014
2 Related Answers
Anonymous
  • 5 Answers
SOURCE: aqualite stopwatch alarm
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Posted on May 22, 2010
http://www.trademe.co.nz/nz/auction-55093452.htm
go to the site & then join community I think someone will help you.
Posted on Feb 11, 2008
How do I turn off the alarm on a RS036 sports stopwatch? This is an inexpensive item but useful now that its fixed with a new battery - but I can't turn the alarm off! :-(
I found with this model, the 'mode' button should be pressed and held in stopwatch mode so that it enters clock mode, then with it held also press and hold 'lap', then toggle the alarm on and off with the 'start/stop' button.
I've just replaced the battery on one that's been running right up to present, for about twelve years and had to familiarise myself with it again during setup, the best deal on a 2016 coin cell for it was a six pack of three pairs, 2016, 2025 & 2032 type batteries: all for 99p.
All the best :)
Sep 21, 2013 • Watches
1helpful
Reset alarm stopwatch start pc396 pressing hourly chime
with the alarm time showing - press the split reset button if the hourly chime is on you will see a row of dots above it. Press the mode button to get the dots to disappear and turn off the chime.
I am unable to set time in watch Nako NA-823A
NAKO NA-823A Instructions
Turn Alarm on or off:
-Press the S and D buttons simultaneously.
Display Date:
-Press the D button.
Set time and date:
-Press the M button to switch modes in this sequence: stop watch>set alarm>set time>time.
-The S button will allow you to select seconds, minutes then hour, then day, month and weekday.
-Use the D button to clear seconds to zero, or move minutes and hours and date up by a single increment.
-Press and hold D for two seconds to move minutes and hours rapidly.
-Press and hold D while pressing and holding S moves through AM/PM and 24 hour (H) modes.
Use stopwatch:
-Press the M button until you arrive at the stopwatch.
-Press D to start and stop
-Press S to clear.
Display alarm time:
-Press the S button while time is displayed.
Jan 14, 2013 • Watches
8helpful
3answers
Instructions for pc396 stopwatch
Hello
PC396 has three buttons. From left to right.
Split/reset, Start/Stop
And mode below.
Mode switches between Time and Stopwatch modes.
By pressing the ****/reset button during the time mode, it will show the current alarm. You can change the alarm by first holding down alarm button and then pressing mode.
To adjust date and time first press down DATE and then press on mode.
if you need further assistance please let me know.
Oct 04, 2010 • Watches
How could I remove alarm on junso 7064 stopwatch? or where I find manual for this stopwatch? thanks
Did you ever find a solution to turning the alarm off this stopwatch.I have the same problem.!!!
9helpful
2answers
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 • Watches
15helpful
3answers
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
26helpful
6answers
Aqualite stopwatch alarm
To set time:
To set Alarm time:
Feb 11, 2008 • Watches
Top Watches Experts
Marvin
Marvin
john h
Are you a Watch Expert? Answer questions, earn points and help others
