Question about Sharp R-1610 Microwave Oven
When pressing the start button, only the timer comes on, and the micro wave turn table and the microwave itself does not operate ? It had been operating intermittenly, now it does not work at all. Shutting the door hard would sometimes make it work.
Posted by bob_gahan on
Mirko
    New Friend:
My Microwave Oven is working OK but turn Table doesn't work.
Posted on Jun 16, 2013
specialistel
    Brigadier General:
  • 8,909 Answers
Check the door interlock switches. If one is not contacting properly due to the door being misaligned, realign the door hinges.
Hope that helps.
Posted on Dec 28, 2010
My microwave is working but the turn table is not turning
next time send the brand name and model number,when you go to work on a micro wave unplug it,even if you change a bulb on it,i've seen people change the bulb without unplugging it and cook the computer board,on the bottom there's a motor that turns thee turn table,drop the bottom panel of the micro wave usually like 6 to 9 screws and on some there could be an access panel just for the motor,unplug the old motor and remove screw or screws,pop off the cover inside the microwave where the glass turn table sits on and,put the new motor in and put it back the same way you took it apart,it's pretty easy to do.go here put your model number in and find part number
https://www.searspartsdirect.com/part-number/241700104/0046/253.html?pathTaken=partSearch&q=241700104
Jan 13, 2018 | Microwave Ovens
Inside light comes on, control panel works, timer counts down, but: table doesn't turn, fan doesn't blow, no microwaves created.
Johnny Appleseed.. hello,
Thnx for all that good nutrition (X-ell-ent companion to cheese)!
Before we start...
An annoying little know trivia about micro-waves...
If used for EMPTY or for softening single pats of butter
they will soon self destruct (eat themselves... burn-out... fail).
When they do... their "micro-wave-generator" (magnetron) will
consume much more energy and cause the primary (most likely solitary fuse to operate)... "blown fuse".
Would that you had included a model number... (but alas).
Looking up your own model number on eBay or better GETTING your REAL PART NUMBER off of your original parts sheet will allow you to shop for the VERY BEST PRICE.
Sears has an excellent reference library... but if you want the same part you can get everywhere else for the HIGHEST price
SEARs ($$$$) is your place... (3 estimates... always!).
Don't forget to get that SPARE FUSE...!
Happy hunting.
appliancepartspros...
Search Over 2 1 Million Appliance Parts
- repairclinic.com
- ezapplianceparts.com
- partssellect.com
Mar 31, 2016 | Microwave Ovens
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Strange one here, The turntable in my Microwave wont turn off, even after timer runs out and micro shuts down when you open the door the turntable just sits there and spins without a care in the world
Power to the turntable motor is supplied by a relay mounted on the main control board ( the part behind the control panel). Sounds like the relay contacts are stuck in the closed (on) position. You can try getting to the main board and tap the small box looking parts on the board with something like a screwdriver handle and see if you can get it to unstick. If that doesn't work---board needs replaced.
Jun 04, 2015 | In Microwave Ovens
Mcc1010t magic chef micro/convection
follow this steps and fix it. God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Jul 13, 2013 | Microwave Ovens
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Sharp R-1610 Microwave Oven Logo
119 people viewed this question
Top Sharp Microwave Ovens Experts
Michael Thomas
Michael Thomas
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
