Question about JVC AV-27230 27" TV
Hi lt40fh jvc how do i get the channel locks off please
    Top Expert:
  • JVC Master
  • 76,237 Answers
Hello
If you forget the Lock Code, a new code may be set using the steps listed below.
After a power interruption you must reset the Lock Code
Channel Guard and V-Chip settings are protected by a four-digit Lock Code. Your TV comes pre-set
with a Lock Code of "0000". You may change the code to any four-digit number you wish. To
change the Lock Code, follow these steps
Press the MENU button
Press "UP" or "DOWN" button RESET LOCK CODE
Press RIGHT or LEFT button to operate
The Lcck Icon appears.
Press ZERO to access the Lock Code
The first digit will be highlighted
Press RIGHT or LEFT button to seelct the number.
Press UP or DOWN BUTTON to move to the next digit
Continue to follow these directions for all four numbers
Press UP or DOWN button To FINISH
Press RIGHT or LEFT button to save settings and exit
Your new Lock Code is now set.
OK.
Posted on Dec 28, 2010
Ctr jvc tv reset lock
Contact the authorized service center for JVC. No other way.
Jan 24, 2014 | Televison & Video
My JVC HDTV station is locked on Channel 3, How do I unlock it from this station
Hello
To unlock the panel lock of your JVC tv do the following.
Turn on the JVC television and press the "Menu" key on the remote control.
Use the Up and Down or Channel buttton to toggle through thre menu selections until V-chip appears.
Stop on V-chip and press the right arrow button to display a padlock icon
Enter the four-digit code by pressing the numbers on the keypad. If a code has not been entered, the default code is 0000 (four zeros).
Press the right-arrow key to unlock the channels
Unplug the JVC television for at least 15 minutes to reset the code to 0000 if a previously set code has been lost or forgotten
OK
Mar 22, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
What is the code to unlock channels for JVC TV
JVC Standard Televisions 'Set Lock Code' are factory set to '0000'
Nov 17, 2009 | JVC Televison & Video
Channels won't change on tv with remote or manually
hi,you need to auto search first your your t.v set if nothing happen possible defect is the tuner.
Aug 03, 2009 | JVC LT-32P679 32 in. LCD TV
Channel locked.
could be a memory error .please contact the nearest repair shop.
Jul 08, 2008 | JVC AV-27230 27" TV
Jvc channel lock
The default lock code is "0000" Then you can go in and turn off the V-chip.
Sep 13, 2007 | JVC AV-20220 TV
JVC AV-27230 27" TV Logo
254 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
