Question about Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2 - my SD card cannot be read. Are there any common reasons for this?
Posted by lscheibmeir on
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: palm tungsten E2
The card is too big for the Palm to read.  You can try 1 gig.  2 gig will work on a TX.
Posted on Sep 13, 2008
Anonymous
  • 448 Answers
SOURCE: Tungsten E2 sd card - photo's
They won't. Your SD card has to be installed in your E2 and you have to load the pics (multiples if you want using your media icon on your desktop software. There are more steps which I know by heart. Do you have the desktop software?
Posted on Dec 30, 2008
Anonymous
  • 448 Answers
SOURCE: Palm Tungsten E2 - music on SD card
Do you have real player on your E2 and your desktop. I can tell you exactly how to do it. Go to fixya live chat and ask for Just_bobz. I had an E2 with 150 songs on it. Mine broke for other reason but I still remember
Posted on Jan 01, 2009
wayne chamberlain
  • 89 Answers
SOURCE: screws for palm tungsten e2
T5 or T6
Posted on Mar 13, 2009
SOURCE: Palm Tungsten E2 doesn't recognize SD Card
I had the same problem and after some research found that the E2 doesn't recognize anything larger than a 1GB SD card.
Posted on Jun 27, 2009
Can't get to info on my disc.
with the 2 gb the problem its that the palm tungsten e2 can't read more than 1gb on a SD, if it does not read even 1gb then the problem may be the contacts can be dirty or broken, other solution may be that you buy the SDHC driver form palm powerups that let you put SDHC memory up to 32gb on your palm, but you need to check first if the contacts of your palm SD slot are not broken!
Jan 15, 2010 | Palm Tungsten E2 Handheld
Palm Tungsten E2
IS the new card empty?
Jul 19, 2008 | Palm Tungsten E2 Handheld
Memory card cannot be identified
Palm devices will only accept a maximum of 1GB SD cards. Sorry.
Feb 22, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2 doesn't recognize SD Card Card Info states that no card is inserted Card inserted with device on Card inserted with device off No recognition Kingston 4 GB
The problem is simply that the Tungsten E2 cannot read SD cards larger than 1 GB. However, there is a solution that will enable it to read larger cards. A driver called PowerSDHC is available from PalmPowerups.com that will enable the E2 to read cards of any size. I'm now running an 8 GB SDHC card on my E2!
Feb 17, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten e2 Palm and durcell sd card
Must go into system on E2 and tell it to format card.
Dec 13, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten e2 and duracell 1 gb memory card
Thall shalt format card for E2
1. Click on time in upper left hand corner
2. Select info
3. On device drop menu select sd card
4. Lower right corner select more
5. Upper right select card
6. Select FORMAT CARD
If you can't format...the card is toast
Dec 13, 2008 | LG Shine KE970 Cellular Phone
Oct 19, 2008 | Palm Tungsten E2 Handheld
Palm tungsten E2
As the previous responder said, the Tungsten E2 cannot read cards over 1 GB. However, there is a wonderful solution available at PalmPowerups.com called PowerSDHC. This wonderful little driver will enable the E2 to read cards of any size! At $20.95, it's a bargain. I installed it on my E2 and now I use an 8 GB SDHC chip!
Sep 13, 2008 | Palm Tungsten E2 Handheld
Expansion card
Has this card worked before in your Palm?
Jun 30, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 (Multilingual) Handheld Logo
Top Palm Computers & Internet Experts
NOEL
NOEL
Pcm2048
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
