Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
My Cobra MPC by schlage lock is locked. The wrong code was entered and now the led lights will not light up and the door will not unlock. How can i reset this?
Posted by apollard81 on
Coaltowner
  • 963 Answers
I don't have a direct answer, but here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Posted on Nov 06, 2011
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage cobra default code
There is no "factory default code". If there was such a thing, you could bet that any good thief would have it-rendering your lock useless as a security device.
Try Schlage.com for further information.
Feb 13, 2012 | Schlage COBRA by Keyless Lock
My residential schlage cobra lock no longer locks. I have checked the batteries. Using the programming instructions, I cannot get a "normal' code to program. I always get flashing lights...
Since you seem to be doing everything properly and following the instructions, I recommend that you contact Schlage for some technical assistance. Here is the contact information:
Olathe, KS 66061
Schlage FAQ:
Instructions & Manuals:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Aug 04, 2011 | Schlage COBRA by Keyless Lock
Schlage Cobra lock. The lock will not lock
Please re-post your question with more specific information about the problem.
Here is the contact info you need for customer service:
Olathe, KS 66061
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Mar 18, 2011 | Schlage COBRA by Keyless Lock
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I have the same kind of problem. I have the programming code, but when I enter it, after entering the 4 th digit the lock blinks an error thinking I entered an incorrect user code?? So I think I might have...
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Aug 30, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
681 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
