Watches Logo
Question about Watches
I have the same watch Mingrui WR30M, its making been sound every 10 mins for around 1min. Not sure what mode is set. How can I stop this from happening.
Posted by nandkumar_ga on
Anonymous
    New Friend:
  • 38 Answers
Reset it
Posted on Dec 28, 2010
  • nandkumar_ga Dec 28, 2010
    how to reset? I tried press-hold reset button... not working out
How do i shutdown hourly beep in mingrui spots watch
To turn off the hourly beep on a Mingrui sports watch, you can try the following steps:
  1. Press and hold the "Mode" button until the watch enters the settings menu.
  2. Use the "Adjust" button to navigate to the "Beep" or "Alarm" option.
  3. Press the "Adjust" button to turn off the hourly beep.
  4. Press the "Mode" button to exit the settings menu.
Please note that these steps may vary depending on the specific model of Mingrui sports watch you have. It's recommended to refer to the user manual for your specific watch for detailed instructions.
Sep 20, 2022 • Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
1helpful
I have a Mingrui company sportswatch.But the instuction paper is not fot my watch.It is WR30M
Call the company and see if they will send the paper work you need to your house.
Jan 02, 2013 • Watches
41helpful
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 • Watches
5helpful
2answers
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Sep 25, 2011 • Watches
Top Watches Experts
Marvin
Marvin
john h
Are you a Watch Expert? Answer questions, earn points and help others
