No duplex option is available. The only way to duplex is manual. Meaning you have to print the first side, then turn the page over and re-insert into the printer. Then print the 2nd page onto the back of the first page. The reason this is not an option and generally you do not want to duplex on these machines is that the ink will tend to bleed thru the paper when prining on both sides of a piece of paper. You may have to use a little thincker paper to prevent this.
Good Luck and Thank You for using Fixya.
WheatlandServices
HP3350MFP - Duplex Printing/Copying
Hello, The HP3350 does not support automatic double sided printing. The HP3390/3392 printers support this option. In order to double side on the HP3350 a manual duplex will need to be conducted, which means running page 1 through the printer, flip the page over and print page 2 for the reverse side. It may be necessary to experiment a few times to achieve the proper printing orientation. You can download a copy of the users guide from the following link.
