Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Replaced HV board on Maytag MFI2568AES fridge. Lights were flashing/ice door flapping...everything seems OK now except that 18 hrs later fridge/freezer cool but not nearly close to proper temp.
Posted by dobermanzia on
Sudeep Chatterjee
  • 3,267 Answers
Increase the thermostat settings to a more cooler temperature
Posted on Dec 28, 2010
  • Paul Sep 28, 2011
    having the same problem...did you figure out how to resolve?
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Blinking board and flapping ice dispenser.
We called Maytag customer service and they resolved our problem and is sending us a new control board and sending out a technican to our home to install at no charge! What great service! Thank you Maytag!
Jun 11, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Blinking board and flaping ice door
I had the exact same problem. Maytag sent me a new main board which fixed the problem. It is pretty easy to install and is located behind the fridge behind a metal panel.
Mar 23, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Ice20 refrigerator
You have a bad high voltage board and as the other user said call the manufacturer they are assisting with this problem.
Jul 09, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Jun 17, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
711 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
