VW passat 2002 tdi- Alternator removal- Top bolt free and bottom bolt loose but cant remove the bolt as too long and keeps catching on fan. Stuck!! help
? 6:09
https://www.youtube.com/watch?v=urBVruIk348
Dec 31, 2011 - Uploaded by 1A Auto Parts
How To Install Replace Engine Serpentine Belt Volkswagen Beetle 1AAuto.com ... Well, the serpentine belt on my Bugbroke. And, didnt know ...
You will see the bolts holding the alternator in place. In most cases no more than three to remove. Before starting the replacment disconnect battery.............hope this help and good luck.....Please rate this.
Follow your top radiator hose back to the engine and at the end of the hose is the thermostat housing usally 2 bolts mount it to the engine.Remove the 2 bolts and pry up on housing thermostat will be underneath.
Well, there is a catch 22 to your plan. In order to remove the radiator you have to remove the fan first. Check around the housing for the fan, you should find plastic pressure clips that hold the fan in place. Release the clips and you should be able to lift the fan housing and shroud out or drop it through to the bottom of the vehicle. To remove the radiator you have to remove the fan shroud and fan in order to locate and remove the retaining bolts for the radiator. There are usually 2 on the bottom of the Radiator sometimes accessible from the bottom of the vehicle and 2 near the top of the radiator, usually covered by the fan shroud.
